Old 05-28-2016, 10:49 AM   #1
bunnyc
bunnyc's Avatar
Default Compression test - cylinder head
My compression test results: 85,86,86,89 (psi)
I notice others post numbers in the 50's.
Does that mean I have an other than stock cylinder head? It's not aluminum.
I have a '30 engine (stock, as far as I know) in a '29 Tudor.
bunnyc is offline   Reply With Quote
Old 05-28-2016, 11:00 AM   #2
Ron W
Ron W's Avatar
Default Re: Compression test - cylinder head
Yes. Ron W
Ron W is offline   Reply With Quote
Old 05-28-2016, 11:06 AM   #3
noboD
And you should be HAPPY.
noboD is offline   Reply With Quote
Old 05-28-2016, 12:20 PM   #4
Mitch//pa
Your gauge may be loose
Old 05-28-2016, 12:35 PM   #5
richsfords
richsfords's Avatar
we just had a friend do a 28 standard head, 63,63,64,64 and with a compression ratio of 4 to 1 figures are good.
Richard in New Bern.
When everything seems to be going against you, remember that the airplane takes off against the wind, not with it” - Henry Ford
richsfords is offline   Reply With Quote
Old 05-28-2016, 12:35 PM   #6
Juggler
Juggler's Avatar
Post pic of head!
I get the same readings on a 6.8 to 1 Winfield aluminium head
And try another compression tester just to make sure....
Juggler is offline   Reply With Quote
Old 05-28-2016, 12:36 PM   #7
bunnyc
bunnyc's Avatar
Originally Posted by Ron W View Post
Yes. Ron W
Thanks for clearing that up. So maybe I should use higher than 87 octane. Without cc-ing the head, I don't know what compression ratio I'm running.
Old 05-28-2016, 12:46 PM   #8
Jim/GA
Jim/GA's Avatar
Probably no need for higher octane fuel.
Your compression ratio is only up around the 5.5 to 6.0 range. Regular fuel is fine for that.
If you hear the engine knock climbing a steep hill, retard the spark a tad (about 1/4 of the quadrant travel) and the knock should stop.
Your compression numbers are quite close to each other, so I'd say all is good. Just go drive it and have fun!!!
Jim Cannon
"Have a Model A day!"
Old 05-28-2016, 12:58 PM   #9
bunnyc
bunnyc's Avatar
Originally Posted by Juggler View Post
Post pic of head!
Pics of head:
Old 05-28-2016, 01:06 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
That first picture is a good one to show the bellcrank for the throttle linage, to show the angle it rests at. This would be for the person that showed a welded link the other day, and was having trouble.
Why such a tall stud on the water outlet?
