10-10-2013, 07:49 PM | #1 |
Black tail pipe
I have had problem with sooty tail pipe and plugs. I have installed smaller main jets which seem to help some; but I have only driven maybe 50 miles around town. How many miles with new jets should it take to determine if the smaller jets are going to take care of my problem and give me nice tan color in tail pipe and spark plugs? I need to clean, if not replace. the spark plugs I am sure.
Thanks, Lawson
Life is like a roll of toilet paper. The closer to the end, the faster it goes. It is better to be seen, than viewed. "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". Last edited by Lawson Cox; 10-10-2013 at 07:54 PM. |
10-10-2013, 08:02 PM | #2 |
Re: Black tail pipe
Lawson, how is your air cleaner, maybe its plugged up. I put on a small one with a K and N filter in it. I could tell there difference when I was starting up the motor. and I could hear it breathe
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
10-10-2013, 08:53 PM | #3 |
Re: Black tail pipe
Check your fuel pressure.
10-10-2013, 09:43 PM | #4 |
Re: Black tail pipe
Oil pressure is fine. I am hoping the test from Uncle Max will give me some clarity.
10-10-2013, 09:46 PM | #5 |
Re: Black tail pipe
It is fine. I am using a good clean oil bath filter.
10-10-2013, 10:17 PM | #6 |
Re: Black tail pipe
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
10-11-2013, 10:02 AM | #7 |
Re: Black tail pipe
Lawson I said FUEL PRESSURE not oil if you were answering my post.
My 34 5W had black sooty tips & ran like stink until I installed a pressure regulator. I could not believe the difference. |
10-11-2013, 01:16 PM | #8 |
Re: Black tail pipe
Whoops, I misread your post. Thanks for the heads up.
What happened to the post by Uncle Max?? gremlins??
10-11-2013, 01:44 PM | #9 |
Re: Black tail pipe
check your pump pressure and that your needle is seating
10-11-2013, 02:31 PM | #10 |
Re: Black tail pipe
No smell of gas at all.
10-11-2013, 02:52 PM | #11 |
Re: Black tail pipe
I had a problem with my tail pipe too. The doctor gave me some pills for it......
10-11-2013, 05:46 PM | #12 |
Re: Black tail pipe
Lawson>>>What happened to the post by Uncle Max?? gremlins?? >>>
Yep, and you're the gremlin who posted another thread entitled "black plugs" https://www.fordbarn.com/forum/showthread.php?t=119886 8^) Jack E/NJ |
10-11-2013, 08:35 PM | #13 | |
Re: Black tail pipe
10-13-2013, 07:51 PM | #14 |
Re: Black tail pipe
Originally Posted by uncle max
Warm it up and give it good run for a 1/2 hour on the road. When it's at speed, push in the clutch and switch off the ignition. Coast to the side of the road and check one or two plugs. This is one of the best ways to get a true reading. This is assuming you don't have aluminum heads, in which case you'd need to let them cool before playing with the sparkplugs. Uncle Max, I followed your instructions to a "T". Worked great. I did clean the plugs before the trip to make them easier to read after the trip. All of the plugs are clean as a pin, and tan on several of them. 60 MPH most of the time but I did sneak up to 70 once. No black or soot on any of them. I haven't checked the tail pipe. I will do that tomorrow. Thanks for the tip. __________________ Life is like a roll of toilet paper. The closer to the end, the faster it goes.
10-13-2013, 07:59 PM | #15 |
Re: Black tail pipe
10-13-2013, 09:57 PM | #16 |
Re: Black tail pipe
good job, Lawson....sometimes you just gotta run 'em hard....or longer time, etc....gets the engine hot enuf to vaporize the moisture in the engine, etc.....now keep drivin'.....Mike
10-13-2013, 10:14 PM | #17 |
Re: Black tail pipe
I had no problems with my other vintage Fords but the pickup isn't quite as high speed friendly, or maybe my youthful age of 82 has slowed me down some, afoot or in an old Ford. LOL
