Old 10-23-2019, 10:34 PM   #1
ianmatt74
Default weird hesitation
I have a 1959 292 y-block, bored .030, pertronix 2, headers, mumert intake, avs2 500 cfm carb, original 4 speed T98. Also running autolite 46 plugs gapped .040. At around 2800 rpm under decent acceleration i get some hesitation. If i ease into that range it doesn't do it and pulls good on up. But put load on it and she falls on her face a bit. Any thought on what could be causing this? what is this a symptom of? Are the secondaries opening too soon?
ianmatt74 is offline   Reply With Quote
Old 10-24-2019, 12:24 AM   #2
50fordcoupeman
50fordcoupeman's Avatar
Default Re: weird hesitation
Just a guess here..........my 302 had similar symptoms and it turned out to be the coil. Hope this helps.
50fordcoupeman is offline   Reply With Quote
Old 10-24-2019, 08:23 AM   #3
Ole Don
Ole Don's Avatar
It sounds like a lean condition. I would check the accelerator pump first.
Ole Don is offline   Reply With Quote
Old 10-24-2019, 10:24 AM   #4
DaleM
Any backfire or cough? Almost sounds lean and that would likely be power valve or accelerator pump.
DaleM is offline   Reply With Quote
Old 10-24-2019, 10:24 AM   #5
scicala
scicala's Avatar
If the ignition is in good shape and advancing properly, and if it's not an issue like accel pump shot from the carb, then I guess it's possible the air valve over the secondaries has the spring set too light, since these carbs are used on a wide variety of engines.
If the hesitation is when you get into the secondaries, then maybe play with the spring tension on the air valve and see what happens. I would say slightly more tension for a first try.
Sal
scicala is offline   Reply With Quote
Old 10-24-2019, 10:26 AM   #6
scicala
scicala's Avatar
The AVS has no power valve to speak of. pretty sure it uses metering rods controlled by manifold vacuum.
Sal
Old 10-24-2019, 02:16 PM   #7
Daves55Sedan
Daves55Sedan's Avatar
Not that this might be related, but you mentioned you have the plugs gapped at .040. Shouldn't it be more like .035 ???
Old 10-24-2019, 03:01 PM   #8
KULTULZ
KULTULZ's Avatar
Post Re: weird hesitation
Originally Posted by ianmatt74 View Post
pertronix 2,
If the spark is hot enough, you can open the gap to get a hotter burn.
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 10-24-2019, 06:27 PM   #9
ianmatt74
Thanks guys I will try a few things like tighten the 2ndary spring flap. I also am going to try autolite 45s at .035. I have played with the holes on the accelerator pump and the bottom hole (smallest shot) is they only one that runs good. the other holes give me bog off the line.
Old 10-28-2019, 08:15 AM   #10
LD-Ordie
LD-Ordie's Avatar
So at some point, was the engine running properly and this problem creeped up?
LD-Ordie is offline   Reply With Quote
Old 10-28-2019, 09:26 AM   #11
KULTULZ
KULTULZ's Avatar
I have a 1959 292 y-block, bored .030, pertronix 2, headers, mumert intake, avs2 500 cfm carb ...
IF you are sure the IGN is 100%, the valves are adjusted properly (proper manifold vacuum), fuel pressure and delivery are 100%, then you may need to go into carb calibration. Your intake and headers are going to give you greater flow through the engine and you may have to enrichen the fuel mixture to get proper performance.
You need to find online the INTR SHEET for the kit shown below to guide you. Make sure you choose correct kit.
Old 11-02-2019, 05:20 PM   #12
ianmatt74
So I jetted in down one size jet and rods, adjusted timing, and have accelerator pump arm in lower hole and the hesitation is almost gone.
