Old 08-10-2019, 05:13 PM   #1
Zax40
Zax40's Avatar
Default ‘37 aluminum intake stud replacement
Early Ford flathead factory aluminum intake. My carb studs, especially the rear one, should really be replaced. Is there a method to getting the old ones out without damaging the intake?
Zax40 is offline   Reply With Quote
Old 08-10-2019, 05:46 PM   #2
JSeery
JSeery's Avatar
Default Re: ‘37 aluminum intake stud replacement
Can you double nut the stud? They should lock against each other and allow you to turn the stud out.
Old 08-11-2019, 01:16 AM   #3
Brian
Brian's Avatar
Vise grips, as tight as you can applied to old stud[s]. Spray with your favourite penetrant. Using your judgement as to how much force to apply to visegips, apply torque back and forth to get stud moving and help penetrant seep down. If the stud[s] refuses to budge, gently apply heat to aluminum surrounding stud, and repeat the twisting motion. Work the stud back and forth a few times to loosen, don't simply crank it all the way out at once; it could seize and snap/strip the aluminum threads. Use your judgement.
To fit the new studs, use the double nut locking method. Could pay to chase the threads in manifold prior to fitting replacement studs.
Old 08-11-2019, 01:40 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
I've always removed the intake carburetor mounting studs by double nutting as mentioned above. Once or twice I've also had to apply some heat to the area around the stud.
John
Old 08-11-2019, 02:26 AM   #5
Brian
Brian's Avatar
By all means; if you can get them out by the double nut method, use that method. At least the removed studs may be fit for further service, unlike the visegrip method, which will bugger them...
The last one I did [two days ago], I needed to resort to visegrips and heat along with penetrant. Main thing is, once you get them to move, keep up a forward/backward motion to free up the threads, don't just unscrew them directly. Good luck
Old 08-11-2019, 07:04 AM   #6
corvette8n
corvette8n's Avatar
Snap-on stud remover I got one off of eBay, work great.
Old 08-11-2019, 09:31 AM   #7
tubman
tubman's Avatar
Brian, Not to be disrespectful, but do you have some special vice-grips that you use for the? I ask this because I have always been able to get better purchase on a stud to be removed (or even installed) using "double nutting". I have a couple of long 1/2" box end wrenches that I use (so I can turn it both ways), and have never not been able to get one out. All of the vice-grips I have (some real, some "off-brand") were clearly inferior in getting a grip on a stud.
Old 08-11-2019, 12:01 PM   #8
Brian
Brian's Avatar
Tubman, No, I just use Genuine vicegrips, [not imitation ones], and clamp them onto the stud really tight. This wrecks the stud; it'll be mightily deformed, but will get the offending stud out, although the real stubborn ones may need a bit of heat.
Old 08-11-2019, 12:58 PM   #9
mrtexas
mrtexas's Avatar
Use a Victor wrench or you will break them off.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 08-11-2019, 02:09 PM   #10
A bones
A bones's Avatar
Have you ever used your big finger, channel locks to close your vise grip?
Yes I am an animal.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 08-11-2019, 07:31 PM   #11
Zax40
Zax40's Avatar
What is a Victor wrench? I'm not familiar with that one.
Old 08-12-2019, 11:30 AM   #12
cmbrucew
cmbrucew's Avatar
Fire dragon
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
