Old 02-20-2023, 10:21 PM   #1
Double Trouble
Default 1930 Truck or Tudor door panel installation
Can anyone tell me the purpose of the D shaped "clip" in the attached closeup of a model A pickup/tudor door?
Does it somehow retain the door panel? If so, how does it?
I've been wondering for years and now that I am at the point of installing door panels I would really like to know. I haven't come across any information about it try as I might.
Double Trouble is offline   Reply With Quote
Old 02-20-2023, 11:01 PM   #2
1955cj5
1955cj5's Avatar
Default Re: 1930 Truck or Tudor door panel installation
I asked that same question several years ago.
I was told that the hook would have been used to secure some interior panels, but not those normally found on a CCPU.
Here is the link...
https://www.fordbarn.com/forum/showthread.php?t=169164
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 02-21-2023, 12:42 AM   #3
Double Trouble
Thanks for the help, I could see the hook being a T/TT cary over in 28/29 but why would they continue them into 30/31?
As the same door will fit Tudor's, I wonder if it might not be intended for them.
I have seen bulging door panels, a center attachment point might keep the panel from doing that maybe.
Old 02-21-2023, 12:59 AM   #4
J Franklin
J Franklin's Avatar
I would be tempted to cut a slot in my panel to fit that on installation.
Old 02-21-2023, 09:41 AM   #5
Double Trouble
I am tempted to do just that, but I have not seen any restored examples of that "hook" protruding through the panel.
I wonder if there wasn't maybe a bracket on the back of the panel? If only someone had an original,Hmmmmm.
Old 02-21-2023, 10:08 AM   #6
Big hammer
On my late 31 tudor, I think that there was a hole in the panel board and the door tab would catch the panel board. This securing the middle of the panel, like I said I think it’s been many years ago.
get a bigger hammer tap done
Old 02-21-2023, 10:35 PM   #7
Double Trouble
Thanks for the responses, I think I'll try to cut a slot in the panel without going all the way through so that the hook is concealed behind the outer covering.
