Old 06-10-2019, 02:22 PM   #1
Duganw
Duganw's Avatar
Default Transmission removal
I'm curious to see if anyone else has had this problem. In removing the transmission/bell housing after removal of the rear end differential assembly from a '28 Phaeton I could not get the U-joint to clear the brake crossover bar, so the tranny and bell housing became stuck between the clutch plate and crossover bar. I finally had to remove the U-joint in order to lower the tranny and remove it. Am I missing a trick?
Duganw is offline   Reply With Quote
Old 06-11-2019, 08:23 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Transmission removal
You did it right. I had to do the same thing, except I lowered the brake cross shaft.
Old 06-11-2019, 09:15 AM   #3
Duganw
Duganw's Avatar
Thanks for the response, so when reinstalling it would be best to remove the brake crossover bar?
Old 06-11-2019, 09:39 AM   #4
Tom Wesenberg
I think so.
Old 06-12-2019, 04:26 AM   #5
larrys40
I usually just remove the ujoint and there’s no need to remove the cross shaft. If you want to put the trans back in with u joint already installed then remove the cross shaft.
Larry shepard
larrys40 is offline   Reply With Quote
Old 06-12-2019, 08:14 PM   #6
jw hash
jw hash's Avatar
larry is right on, I always remove the Ujoint
jw hash is offline   Reply With Quote
