Old 04-22-2023, 01:38 PM   #1
The "A" Team
Default What is leaking by my wheel?
Hi,
I just pulled two of my wheels off to replace the tubes and clean up/de-rust the brakes. After I put the front and rear wheels back on, i drove it out of the driveway to turn it around. I left it for a few minutes to eat lunch and when I came back out I noticed some liquid by the rear wheel and saw it dripping from somewhere around the castle nut. There was actually a small puddle of liquid gathering in the middle of the wheel. It doesn't look like oil or gas, and doesn't bead up when water touches it, and doesn't really have a smell to it, which makes me think maybe it's water.
I don't know where it could be coming from. Everything was removed from the rim and new tubes were installed with the tires.
The "A" Team is offline   Reply With Quote
Old 04-22-2023, 02:31 PM   #2
1955cj5
1955cj5's Avatar
Default Re: What is leaking by my wheel?
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 04-22-2023, 02:36 PM   #3
Tom Endy
Tom Endy's Avatar
It appears differential oil is leaking out down the axle shaft past the seal in the axle housing that is probably shot and past the small seal behind the axle shaft nut, that may not be there.
Tom Endy
Old 04-22-2023, 02:50 PM   #4
nkaminar
nkaminar's Avatar
Usually there is a seal at then of the axle. See https://www.snydersantiqueauto.com/p...8134&cat=41627. In the photo it looks like oil. If it is water then it may be from rain or from running through a puddle.
Old 04-22-2023, 03:03 PM   #5
Dave in MN
Dave in MN's Avatar
Seriously, it was a dog! The color of the liquid in the wheel hub is yellowish.
Good Day!
Dave in MN is offline   Reply With Quote
Old 04-22-2023, 03:03 PM   #6
The "A" Team
I just pulled off the other hub and it also looks like there's something around the shaft. It's clear and doesn't smell like anything, so I'm thinking it could be water.
I also forgot to mention that the car was sitting by my parents' house In a leaky garage in an area that also flooded whenever there was heavy rains. I brought the car over to my house about a year and a half ago, but never saw anything leaking from the wheels until I pulled the hubs off to clean up the brakes. And it's only happening in the back wheels.
Old 04-22-2023, 06:29 PM   #7
Big hammer
Water in oil makes a milk shake like mixer, you second picture. Might be time to drain the rear end oil and flush it out
get a bigger hammer tap done
Old 04-22-2023, 06:35 PM   #8
JoeCB
JoeCB's Avatar
Yep' water in the oil. Anyone that has experience with outboard motor gear case lubrication will recognize that "milk shake" color... water/ oil emulsion.
Joe B
JoeCB is offline   Reply With Quote
Old 04-23-2023, 07:02 AM   #9
nkaminar
nkaminar's Avatar
I am with Big Hammer on this one. Drain the rear end and flush it out. Run the car for a while then do it again. Repeat until no more water in the oil. Or, better yet, take the rear end apart and thoroughly clean it out.
Old 04-23-2023, 07:30 AM   #10
Benson
Benson's Avatar
Update 04-23-23 1015: Since POST #6 says that car has been flooded:
Running or driving the car with water in the transmission, Engine and Steering gear will also cause damage!
Old 04-23-2023, 09:44 AM   #11
harryc
well..................where is the water coming from?
harryc is offline   Reply With Quote
Old 04-23-2023, 09:46 AM   #12
Flathead
Flathead's Avatar
Taste it
Flathead is offline   Reply With Quote
Old 04-23-2023, 10:34 AM   #13
rotorwrench
rotorwrench's Avatar
My nose isn't what it used to be but I can still detect odors of gear oil (sulfuric stink) and gasoline pretty easy. Urine generally smells unless the dog or person has been drinking a lot of water.
Water only temporarily mixes with either fuel or oil. It's heavier so it always settles out on the bottom. If there is water in the banjo then it will drain out first if the drain plug is pulled. If a person just drove the car then it will milkshake for half a day or so but always settles out after a period at rest. The differential case would have to have a lot of water in it to come out into the brake drum around the axle seals.
We're the tires removed to replace tubes? We're the wheels removed to do that? If removed, did they come in contact with water? If the answers are all no then I would chalk it off to the unknown and not worry too much about it.
Old 04-23-2023, 10:59 AM   #14
veggie
veggie's Avatar
Send a message via AIM to veggie Send a message via Yahoo to veggie
Hi 1955cj5
That is beautiful humor.
veggie is offline   Reply With Quote
Old 04-23-2023, 11:14 AM   #15
Marshall V. Daut
I guess that if a dog really had caused that puddle, it's a different kind of "leak" than we car guys would expect.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 04-23-2023, 11:35 AM   #16
J Franklin
J Franklin's Avatar
Pull the drain plug on the banjo and see what comes out. If water then do the transmission and anything else that can be wet.
Old 04-23-2023, 05:34 PM   #17
Synchro909
Synchro909's Avatar
Originally Posted by 1955cj5 View Post
Made me remember a time I was having new tyres fitted to my car. I was standing at the front of the business (an old service station) when a guy came in and started checking his tyres. He unscrewed the valve cap, put it in his lips and started to inflate the tyre The owner of the place said that this guy does this every week or so and bought nothing. He said watch this. He went to he guy and asked "You've got the valve cap in your mouth - don't dogs ever piss on your wheels?"
Pteeew and the cap flew across the concrete.
I'll never forget that moment and I've never put the valve cap in my lips since.
Old 04-24-2023, 09:48 AM   #18
Flathead
Flathead's Avatar
No guts no glory.
Old 04-24-2023, 10:56 PM   #19
updraught
updraught's Avatar
updraught is offline   Reply With Quote
Old 04-25-2023, 05:44 AM   #20
nkaminar
nkaminar's Avatar
"I also forgot to mention that the car was sitting by my parents' house In a leaky garage in an area that also flooded whenever there was heavy rains."
Very possible water got into the rear end when the car was standing in the flooded garage. As I stated above, the best solution is to take the rear end apart and clean it out. If that is not in the cards then drain the rear end, grease the bearings, repeat until no evidence of water.
