Old 08-20-2020, 09:57 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Removing oxidation from NOS radiator core
I posed this same question on a thread several years ago but I cannot locate it in the archives and my fading memory cannot recall all of the great suggestions given to me. I have a NOS radiator core, still in the box, that is covered with fine film of oxidation on the brass. I need good solution for removing the oxidation before painting. Looking for information to refresh my memory.
Also, what is the correct nomenclature for the felt covered glass channel pieces that fit in the rear edge of the front doors that the glass slides back into when "cracking" the window for ventilation. We call them "Bat wings" around here, but that is not a Ford term.
Much appreciation from an old man with a bad case of CRS.
Lawson
Old 08-20-2020, 10:10 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Removing oxidation from NOS radiator core
I would mix up a few gallons of water with white vinegar, pour it in, gently shake it for about 5 min. and then pour it out and rinse with clean fresh water. Repeat as needed.
Old 08-20-2020, 10:20 PM   #3
Lawson Cox
Lawson Cox's Avatar
What ratio of vinegar to water? Do you need to neuteralize the vinegar in any way?
Old 08-20-2020, 10:28 PM   #4
FlatheadTed
FlatheadTed's Avatar
Deap channel whiskers /rear deap channel ,Smokers vent channel .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 08-21-2020, 01:06 AM   #5
V8COOPMAN
V8COOPMAN's Avatar
Lawson....Just to be clear, you're talking about this oxidation being on the OUTSIDE of the radiator, correct? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-21-2020, 02:08 AM   #6
ford38v8
ford38v8's Avatar
Remember, Lawson is in Georgia!
Alan
ford38v8 is online now   Reply With Quote
Old 08-21-2020, 07:59 AM   #7
19Fordy
19Fordy's Avatar
Lawson, I would add 1 cup vinegar to 4 gal water. Soak and rinse, rinse, rinse till it's nice and clean and you don't taste the vinegar.
Old 08-21-2020, 08:56 AM   #8
1931 flamingo
1931 flamingo's Avatar
Like V8COOPMAN I also believe he's talking about the outside..............
Paul in CT
Old 08-21-2020, 09:10 AM   #9
KiWinUS
KiWinUS's Avatar
Get a plastic cement mixing tub from Lowe’s the big one. Then stop be supermarket & get some quarts of Coke. Enough to cover core. Let soak a few hours then rinse off. Good luck.
Old 08-21-2020, 09:21 AM   #10
RalphM
RalphM's Avatar
When I worked at a radiator shop in the 70’s, we would use Muratic acid to clean the inside of the radiators before I painted them. It got them shiny as new on the inside, If any got on the outside it would do the same.
Just don’t leave them more than a few seconds if using pure acid. A watered down batch would work better I think.
RalphM is offline   Reply With Quote
Old 08-21-2020, 09:26 AM   #11
glennpm
glennpm's Avatar
... and for anyone with an aluminum radiator, don't do this. You will end up with a nice gray tank.
Old 08-21-2020, 10:06 AM   #12
5851a
An old boss of mine took his radiator out of the tractor and decided to flush it with muriatic acid once. Filled it up and left overnight, next morning had a clean leaky radiator and a hole in the concrete that was under it.
5851a is offline   Reply With Quote
Old 08-21-2020, 10:16 AM   #13
philipswanson
Also a phosphoric acid diluted with water will work great. That was the reason for using coke in the post above. You can find some in the paint department of any Home Depot. Also great for general de-rusting. Light oxidation is ok to leave, just shoot it with a light coat of some black lacquer. The residue left behind (phosphoric coating) will actually prevent further oxidation.
philipswanson is offline   Reply With Quote
Old 08-21-2020, 03:26 PM   #14
Lawson Cox
Lawson Cox's Avatar
That's all I can see. May be on inside of tubes as well. I'm figuring to soak the whole thing to get both inside and outside surfaces.
Old 08-21-2020, 03:32 PM   #15
Lawson Cox
Lawson Cox's Avatar
Just damn. I was planning on using the vinegar on tossed salad with a little MMO. Oh well.
Old 08-21-2020, 03:33 PM   #16
FlatheadTed
Washing soda to check it every few hrs ,
Old 08-21-2020, 04:28 PM   #17
Lawson Cox
Lawson Cox's Avatar
Ted. What is "Washing soda"? We're up here on the top side dontcha know? LOL.
Old 08-21-2020, 06:11 PM   #18
FlatheadTed
Hi Lawson ,Washing soda is a additive for the washing machine ,mild form of caustic soda.you might find more about it on the Model A , ,,Ted
https://www.fordbarn.com/forum/showt...t=washing+soda
Old 08-21-2020, 08:07 PM   #19
JSeery
JSeery's Avatar
Washing soda, aka sodium carbonate(or soda ash), is a natural cleaner and a powerful water softener. It has a very high ph, 11, so be careful.
