02-01-2019, 01:39 PM | #1 |
Hot air heaters
Did Ford offer a hot air heater on cars and trucks after 1940,and if so for how many year models?
02-01-2019, 02:56 PM | #2 |
Re: Hot air heaters
I think 46 was the last year the Hot Air heater was offered.
02-01-2019, 04:01 PM | #3 |
Re: Hot air heaters
Hot water heaters are still offered on New Fords.
02-01-2019, 04:31 PM | #4 |
Re: Hot air heaters
Why would you need to heat hot air?
02-01-2019, 04:44 PM | #5 |
Re: Hot air heaters
I'm guessing the OP is asking about manifold style hot air heaters.
02-01-2019, 05:10 PM | #6 |
Re: Hot air heaters
This was available for 1940 as well as a hot water heater. Wondering how much longer in production and configuration on other years there were. |
02-01-2019, 06:17 PM | #7 |
Re: Hot air heaters
There was a hot air heater option on 46-48 cars, they "came on" quickly, the exhaust heat exchanger was "UL" listed , I have a nos one for 6 cyl
02-01-2019, 07:22 PM | #8 |
Re: Hot air heaters
I had one in my 47 coupe. It was most definitely factory installed.
02-01-2019, 08:05 PM | #9 |
Re: Hot air heaters
I have the part that goes against the rad there is not a part # for it in the diagram it has also the hanging brackets 18558 .If some one could use it give a connect Johnny
02-01-2019, 08:18 PM | #10 |
Re: Hot air heaters
That would be p/n 01A-18577
