Old 01-17-2020, 12:24 PM   #21
Bored&Stroked
Bored&Stroked's Avatar
Default Re: exchange 8ba cyl heads with 59ab
Originally Posted by tubman View Post
Wouldn't you try to "port match" the water passages in the early block to match the late gaskets and heads where possible?
Yes - that is my general idea here . . . but this is bench racing, have not compared both blocks up close and personal (though I have both sitting in my shop).
I'll take some pictures for shits and giggles . . .
Old 01-17-2020, 01:08 PM   #22
tubman
tubman's Avatar
I, for one, would like to see them.
Old 01-17-2020, 04:07 PM   #23
Pete
Pete's Avatar
This works well for circle track. There are 4 inlets on the top of the heads but no pic of that.
It worked ok on the street once also but water flow was in the normal direction there.
Old 01-17-2020, 04:33 PM   #24
JSeery
JSeery's Avatar
That was my understanding. The head gasket controls the water flow, IF the corresponding water passages are there in the block (as in added).
Old 01-17-2020, 11:25 PM   #25
outlaw
I would think that if you were to "port match" the water passages in the 59ab block to match the 8ba style heads you probably would not be able to use the earlier heads again if you ever wanted to.
outlaw is offline   Reply With Quote
