Old 06-12-2018, 07:53 PM   #21
Y-Blockhead
Y-Blockhead's Avatar
Default Re: DynaBeads, yay or nay?
Old 06-16-2018, 02:11 PM   #22
Ruth
Just thinking out loud, Wouldn't a mounted tire/tube inherently be out of balance by design? I would think the valve stem being heavier in one spot would throw the assembly off balance by itself.
At any rate I think the beads work well.
Old 06-18-2018, 08:17 AM   #23
john in illinois
john in illinois's Avatar
I tried them, but don't know if they worked. My wheels were too out of round and would not balance. I suspect a lot of headlight bouncing is due to out of spec wheels.
John
john in illinois is offline   Reply With Quote
Old 06-18-2018, 04:25 PM   #24
barkleydave
barkleydave's Avatar
1963 tires!! Hope you are not driving on them.... time to upgrade for safety first.
barkleydave is offline   Reply With Quote
Old 06-20-2018, 10:27 PM   #25
Rich in Tucson
Rich in Tucson's Avatar
Why not just add water?
Rich in Tucson is offline   Reply With Quote
Old 06-21-2018, 05:34 AM   #26
aermotor
hmm - maybe, farm tractors added water for weight with no problems.
John
aermotor is offline   Reply With Quote
Old 06-21-2018, 05:44 AM   #27
aermotor
John
But then again the possibility of straight water freezing, breaking up and sharp points puncturing the tube.
John
Old 06-21-2018, 09:01 AM   #28
Steve_KS
Tractors use various fluids. The usual favorite is calcium chloride, if your tubes leak any or you get a puncture you need to wash that stuff off ASAP or anything it gets on will be rusty within the day. Other fluids are used too that aren't as dense but are easier to work with, beet juice, windshield washer fluid, water. When you fill a tractor tire you fill it so the liquid is up over the top of the rim to reduce sloshing. You want the liquid to stay in one spot and your tire move around it so you have less stress on the system.
A tractor tire runs over uneven surfaces at very low RPM. I have no idea what liquid would do in a car tire spinning at much higher RPM's.
Steve_KS is offline   Reply With Quote
