01-25-2018, 02:38 PM | #1 |
Tie-Rod Question
Hey All,
I'm installing a new tie-rod, end's and ez steering kit and a new drag link but I'm having difficulty in installing the tie-rod ends onto the balls. Seem's the spring is just to powerful to move and the ball barely fit's the opening without the spring and cap installed. I have filed a small chamfer in the tie-rod end and a slight relief in the bevel on the nylon, ... NOPE. I then used a wood F-Clamp with the end cap slightly threaded in for support, ... not a chance in hell. Next thought, would be to press the tie-rod end onto the ball and then take a 5/16 plastic dowel with a ball end on it and hopefully smack the nylon seat back for a split second. All new parts, tie-rod, both ends, ez kit, steering arms, am I missing something here? Regards Bill |
01-25-2018, 07:05 PM | #2 |
Re: Tie-Rod Question
Have you got all the OLD pieces out??
Paul in CT |
01-25-2018, 08:17 PM | #3 |
All part's involved are brand spankin new.
I got it handled, ... a BFH was in order. Regards Bill |
01-25-2018, 08:22 PM | #4 |
Two thumbs up. . Jeff
Let's let pylons, be pylons! |
01-25-2018, 08:44 PM | #5 |
Glad you got it on! One of my go to tools!
01-25-2018, 09:58 PM | #6 |
I think what Paul in CT(1931 Flamingo) is asking, although you say that everyting is new, “is anything not perhas stuck in there” There is a little brass cup to hold the spring in position and sometimes they are stuck in the back by old grease.
Regards Chris Cape Town 28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC |
01-26-2018, 02:41 AM | #7 |
If they are too tight, it will be hard to steer!
