Old 08-19-2019, 09:45 PM   #1
DannL
DannL's Avatar
Default Observation: sediment bowl seal
While tracking down the smell of fuel, I noticed that the sediment bowl was full of junk again. After removing and cleaning the bowl, I inspected the underside of the bowl housing and noticed that the seal was cork, which had turned to powder. Having just replaced the tires I had spare inner tube material and made a rubber gasket. And now the observation . . . when you have a good seal at the sediment bowl on my car, if you just open the fuel shut off valve . . . no fuel will flow into the bowl. Not a drop. For a moment I thought the fuel line was clogged. Nope. It wasn't until I loosened the bowl would it fill up with gas. I thought that was an interesting observation.
DannL is offline   Reply With Quote
Old 08-19-2019, 11:19 PM   #2
whirnot
whirnot's Avatar
Default Re: Observation: sediment bowl seal
Yep, you have an air lock between there and the carb needle.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 08-20-2019, 06:23 AM   #3
Joe K
Joe K's Avatar
Fuel can't come in until the air can get out.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 08-20-2019, 07:11 AM   #4
old31
Just open up the nut at the carb end a tiny bit and let the fuel flow for about 2-3 seconds and that will push out the air.
Not too sure how long the inner tube will last.
Old 08-20-2019, 07:26 AM   #5
JOHN CT
JOHN CT's Avatar
Your carburetor is full of gas it wouldn’t let anymore gas in. I just drive the car and it fills back up in a few miles.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 08-20-2019, 07:28 AM   #6
DannL
DannL's Avatar
Not sure either. Though it might work okay. I plan on using it only as a temp fix. Since carburator gaskets are mostly just cardboard it seems . . . might try that also.
Old 08-20-2019, 09:03 AM   #7
Dirtrack49
Dirtrack49's Avatar
Happens to me all the time on several vehicles.
I replace the gasket with a new cork gasket anytime I take off a fuel bowl. If you don't, they usually end up leaking since the old cork has taken on a set from the glass bowl.
Tom L.
Dirtrack49 is offline   Reply With Quote
Old 08-20-2019, 09:46 AM   #8
Tacoma Bob
Tacoma Bob's Avatar
Don't trust the inner tube rubber. I use cork as I have had bad luck with neoprene too.
Tacoma Bob is offline   Reply With Quote
