11-22-2022, 04:42 PM | #1 |
Steering worm gear bearing
I am rebuilding my 7 tooth steering box and want to make dure to put the thrust bearings in correctly. Which side goes against the bushing and which agsinst thw worm gear? Thanks.
11-22-2022, 06:48 PM | #2 |
Re: Steering worm gear bearing
will this help
www.whidbeymodelaclub.com Last edited by Gary WA; 12-30-2023 at 02:36 PM. |
11-22-2022, 08:15 PM | #3 |
When assembling those 7 tooth steering boxes, it is important that there be NO end play in the shaft, yet it turns with little drag. To get a really good engagement between the worm and sector, those with the equipment and know how make eccentric sector shaft bushes to get optimal engagement between the two.
The 7 tooth steering box seems to have a bad reputation but if assembled with care, they are actually quite good.
11-23-2022, 11:22 AM | #4 |
The thrust should be away from the worm both top and bottom.
11-24-2022, 12:23 AM | #5 |
