Old 05-29-2019, 05:42 AM   #1
mike dixon
Default adjusting transmission bands
is there a good thread on adjusting the bands on my T?
when I pull my lever, it dont put car in nuetral
mike dixon is offline   Reply With Quote
Old 05-29-2019, 06:23 AM   #2
29spcoupe
29spcoupe's Avatar
Default Re: adjusting transmission bands
Mike, the problem may not be the bands. If the brake handle is the 'lever' that you pull, there is an adjusting bolt on the brake equalizer pawl. Turn the bolt down to adjust your neutral. You should also check your slow speed connection on the forward pedal. That is the adjustable clevis which is connected to the pedal. A Model T service manual will give you the correct way to adjust this. John
29spcoupe is online now   Reply With Quote
Old 05-29-2019, 09:24 AM   #3
redmodelt
redmodelt's Avatar
http://www.mtfca.com/discus/messages...tml?1275744434
Old 05-29-2019, 09:32 AM   #4
Royce P
Royce P's Avatar
You have to look at how everything is adjusted, because it all works together. Here's what I do:
https://modeltfordfix.com/adjusting-...on-and-clutch/
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
