11-25-2022, 04:05 PM | #1 |
1940 Ford oil Pan
there is some kind of a slot or vent on the front passenger side of the oil pan on my 40 Ford coupe. it that supposed to be there and is it some kind of a breather? Should oil be coming out of there?
11-25-2022, 05:41 PM | #2 |
Re: 1940 Ford oil Pan
part of the engine vent system
11-25-2022, 06:54 PM | #3 |
Yes it is a road draft tube. If oil is really flowing from there you have a problem. If just a little misty staining then it is probably normal.
There is a tube inside the valve chamber that connects to this breather passageway. If that is missing you might get a lot of oil going down there. Mart. |
11-25-2022, 10:02 PM | #4 |
Chewie.... As Alan says, it's part of the crankcase ventilation on'35 thru '48 engines. That front pan thingy is the point of crankcase air intake, as seen in the drawing BELOW. As Mart said, there is SUPPOSED to be a tube in the front corner of the valve chamber (seen BELOW) which mounts above that vent orifice at the pan's surface. If this tube is not in place, or if it has been dislodged in some manner, circulated oil could seep directly down that hole, causing the symptoms you describe. Coop |
11-25-2022, 10:55 PM | #5 |
Actually coop, that illustration showing the breathing is backarseward!! it shows a pipe from the oil filler cap to the air cleaner. That is not original....originally, air enters the engine through the filler cap/breather, circulates through the engine and exits at that vent in bottom front of pan.
11-25-2022, 11:03 PM | #6 |
11-26-2022, 05:17 AM | #7 | |
Brian.... I would be inclined to believe that too, as the routing shown in the drawing goes against anything I had ever read, especially when considering common sense and the "DRAFT" theory while the vehicle is in motion. Coop . |
11-26-2022, 05:36 AM | #8 |
Yeah the addition of the tube from oil fill area to carb side of the filter reverses the flow.
11-26-2022, 08:15 AM | #9 |
This is the correct ventilation for production 221"/239" '35-'48 flatheads. Sorry about the small size but I had no luck enlarging it. (:
11-26-2022, 08:47 AM | #10 |
11-26-2022, 08:52 AM | #11 |
8BA stylee:
11-26-2022, 07:03 PM | #12 |
Confused...which way is it?
My 40 / original engine shows blow by out the oil fill breather |
11-26-2022, 07:09 PM | #13 | |
In the first picture shown you can see where someone has retouched all the arrows to point the other way. This is not the stock setup and is only confusing matters. Mart. |
11-26-2022, 07:17 PM | #14 |
Post #9 and #10 are correct. The bottom is the exit, top is entrance.
11-28-2022, 05:10 PM | #15 |
I've gotten blow by smell from the oil filler cap on some older flatheads I've run. Not disputing the flow, just an interesting observation.
11-28-2022, 05:39 PM | #16 |
When you see oil film on the oil pan vent and vapor plus fumes coming out of the breather on the oil fill tube its caused by the pressure that's going into the oil pan area of the engine. Those two areas are actually vents. That pressure needs to go someplace.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
11-28-2022, 07:29 PM | #17 |
Sorta kinda related, my Willys M38 army jeep was made to be run submerged in water. The engineers figured there is about 2 lb's of pressure in the crankcase if you sealed it closed. They then used that pressure to blow air out, instead of water running in. Also ran that pressure to the trans and transfer case and distributor to keep water out. It has a manual valve at the PCV to close it and make pressure. Todays history class...over
