07-05-2021, 02:13 PM | #1 |
64 Galaxie wrong ball joint ????
I cannot install the ball joint and bumper. The bumper shape prevents me from installing like I think it should go. The way the picture shows, I think the bumper is in backwards BUT the ball will not let me bolt up any other way.
07-05-2021, 06:51 PM | #2 |
Re: 64 Galaxie wrong ball joint ????
Where did you source the parts, manufacturer and PN's?
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
07-05-2021, 06:55 PM | #3 |
Are you sure that when you take-up the balljoint that the knuckle of the spindle assembly will not be hitting the upper A-arm? I guess I think that ball jpoint looks like the wrong part....
07-05-2021, 08:44 PM | #4 |
How do the new parts compare to the old parts? Did you take a picture of everything installed before you took it apart? First rule if this is the first time your doing something
07-17-2021, 02:59 PM | #5 |
The rubber bumper was not the problem, it was the ball joint stem was 10thousands too large in diameter and 3/16 of and inch too long. I purchased Moog ball joints and bingo, the were correct and went in perfectly. Moog cost 2x as much but you cannot go wrong with quality over price. What a headache for no reason.
07-18-2021, 09:01 AM | #6 |
