Old 06-05-2016, 09:18 AM   #1
Rocketdog1
Rocketdog1's Avatar
Default Steel or cast iron???
Can anyone tell me by looking at these pics if the drums are original steel or newer cast iron?
The whole package looks like a pretty fair deal, especially if the drums are cast iron.
Also, '30 and '31 brake assemblies are the same, yes?
Thoughts?
http://seattle.craigslist.org/kit/cto/5616791310.html
Rocketdog1 is offline   Reply With Quote
Old 06-05-2016, 09:37 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Steel or cast iron???
look like steel drums to me ---yes, 30--31 same functionally
Kurt in NJ is online now   Reply With Quote
Old 06-05-2016, 09:50 AM   #3
JD 1931
JD 1931's Avatar
steel
JD 1931 is offline   Reply With Quote
Old 06-05-2016, 09:52 AM   #4
Joe K
Joe K's Avatar
Look to be steel.
There was a rough cast brake drum used late in '31, but these don't appear to be.
The 30 or 31 brake components are pretty much identical, at least according to my now obsolete Judging Standards.
This looking sort of like a Model A that got rodded, or someone converting to hydraulics (good luck with that - the limitation on stopping is on the contact with the pavement.)
And turning a steel drum is something fraught with some peril. Whether "ground" or single point turned. (Better ground according to some) And there is a "minimum thickness" one doesn't go beyond. Snyders: Old original brake drums should be no less than .130 thick. Fiddybits of this board says ".130 is the minimum for cast drums and the .120 is for steel."
Joe K
Shudda kept the horse.
