11-17-2019, 04:06 AM | #41 | |
Re: y-block blow by..
The 1960 up FYB PCV design is adequate (IMO) for the engine. There is a baffle on the underneath of the valley pan to direct air flow to the cylinder heads. You would also have to fabricate baffles for the rocker covers with the later design. If the late OEM System is installed correctly, evacuation should be more than adequate, again IMO.
***** - MULTI-VEHICLE SYNTHETIC TRANSMISSION FLUID - Multi-vehicle transmission fluids are becoming more and more popular in the marketplace. Oil marketers design these fluids for a wide range of automatic transmission types. While they are not licensed by any specific auto manufacturer ... ??? ... enough said ... DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
11-17-2019, 04:16 AM | #42 | |
Because of your intake type (plenum hanging over valley cover). there will have to be a few modifications. Where the problem here is that the PASS CAR had the ROAD DRAFT SYSTEM mounted on the LF engine skirt (BIRD used road draft tube) and EDEL made no allowance for either a tube or PCV. The intake plenum overhangs at that spot. To begin, using the OEM PCV design, you will have to find a later PV valley pan and offset the plumbing (elbow) from under the plenum to where you can fabricate correct plumbing. IMO, the system needs to be hidden as much as possible for appearance. Do you live in Pittsburgh or an outlying area?
11-17-2019, 04:37 AM | #43 |
I live east of city, Monroeville...
11-17-2019, 09:40 AM | #44 | |
11-17-2019, 09:49 AM | #45 |
Since you drive the car daily in good weather, the fix may be to modify a set of original valve covers for a PCV system. The covers are very easy to swap out so just put your fancy ones on for shows, and the OEM ones for driving. Glue the gaskets to the covers and put a little high temp grease on the head surface so the gaskets don't stick.
Then if someone wants a ride, they won't need a gas mask! |
11-17-2019, 11:05 AM | #46 |
I readily admit that I am extremely CDO (correct alphabetical order of OCD). What you are describing would blend perfectly with a external rocker arm lube kit. I see your point if it was a beater or truck application. I am sure the OP wants a clean driver without having to change rockers overs on a regular basis. But this engine has three deuces and is partially dressed. Please don't hate me ...
11-17-2019, 11:11 AM | #47 |
Look what I found in an older post -
Y-Blockhead has a perfect install. I am not sure if the EDEL is a 553 or 573, but everything fits.
11-17-2019, 11:48 AM | #48 |
They seem readily available on evil-Bay and other sources.
11-17-2019, 11:55 AM | #49 | |
EDIT: I have seen the style that included a curved/bent oil fill tube to make room for a radiator overflow tank - these all had the oil baffle in the rear as well like the 55 ECJ version...
Lancaster, California Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan! Last edited by Hot Rod Reverend; 11-17-2019 at 01:47 PM. |
11-17-2019, 12:41 PM | #50 |
A lot of good input guys! As I recall my valley pan only had the front baffle in it. I remember that cuz I had a difficult time getting it into the block.I don't recall there being any type of baffle on the rear of it. Could this be causing an issue? Also I forgot to mention I have about 18 to 20 lb of vacuum at idle. And the gauge is reading all the way up in the green zone meaning engine is good. So I'm quite sure it's getting enough vacuum..
11-17-2019, 01:28 PM | #51 |
I have had a lot of experience with the Ford Y-block's, have had one or more in my life since 1959, currently have three F100's, '59- 63.
Many years ago I found out that the pre '63 Y-blocks were very dirty engine because the engine had poor ventilation. In most cases I harvested the PCV systems from a '63 or later F series truck, installing same on my 56-57 T-birds and 59 and later F series trucks. I have one '59 F100 4x that I used a variation of a GM PCV in the right side valve cover. Blocked off the road draft tube located on the lower left side of the block, used a vented/filtered cap on the oil fill tube and a GM PCV and grommet in the valve cover. I located the PCV between two rocker arms and made a baffle for the bottom of the valve cover, at high RPM's there is a lot of oil flying around the rocker arm chamber. In order for a PCV system to work it must be able to draw fresh air through the crankcase/valley, (filtered cap on fill pipe) then into the intake, via the PCV, where it is consumed via the intake/fuel process. Most people want to over engineer the system..
Bill.... 36 5 win cpe |
11-17-2019, 06:26 PM | #52 | |
YO!
Does that explain it adequately and what pictures would you like to see (if I have them)?
11-18-2019, 09:04 AM | #53 |
The PCV pan is the one I would like to see photos of... I don't think I have ever laid eyes on one. I guess I always assumed that Ford used the 55 Tbird/ECJ version and adapted a PCV fitting to an existing design. Go figure.
Lancaster, California Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan! |
11-18-2019, 02:14 PM | #54 | |
The second the 63/64 292 LT pan.
11-18-2019, 03:12 PM | #55 |
these pans are all the same except for filler spout including the 55 tbird.
11-18-2019, 03:48 PM | #56 |
Another difference in Y-block valley pans with a road draft fitting at the back...
There are different outside lengths of the straight oil filler tubes. Most T-Bird valley pan tubes are approx 6 to 6.5 inches long from the top surface of the valley cover, on other vehicles they are approx 8 inches long. Presumably because there's more room under the hood. . Last edited by dmsfrr; 11-18-2019 at 07:51 PM. |
11-18-2019, 04:47 PM | #57 |
Ok, so there is not a pan made from 1960 on that was specifically for PCV? lol now I am confused. I have the pan that dmsfrr shows (from a 1957 Ford) but I installed the PCV plumbing that Kultulz shows in both pictures above (albeit one has the crazy bend in the oil spout for a radiator overflow tank and the other one is straight). Is not the pan on the right in Kultulz's post the same pan as the one that dmsfrr pictures?
dmsfrr - did not know that the T bird pans had an oil spout 1/5" shorter, but it surely makes sense.
11-18-2019, 07:21 PM | #58 | |
The earlier pans that had the actual road draft tube at the rear of the pan can be used for a PCV conversion. Same basic design. Does this help? I seem to not being able to describe correctly ...
11-18-2019, 07:38 PM | #59 |
Here is more info that you may find helpful -
11-19-2019, 04:29 AM | #60 |
Did I explain it to your satisfaction Rev? Haven't heard anything ...
