Old 04-20-2020, 11:35 AM   #1
Clem Clement
Clem Clement's Avatar
Default Hornwire polarity
The horn wire from the horn button to the horn coil makes a ground connection, right? Since my after market tooter is non-Ford and l had two terminals, does it matter how I wire the horn?
Old 04-20-2020, 12:14 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Hornwire polarity
The button in normally the ground for the horn or horn relay depending on the year of the vehicle. A horn with two terminals will have power to one and grounding control to the other. What year model are we dealing with here?
Old 04-20-2020, 12:39 PM   #3
Clem Clement
sorry: 1939 Ford peekup
Old 04-20-2020, 06:12 PM   #4
G.M.
The horn itself can be hooked up either polarity if it has two terminals.
Some horns work on 6 or 12 volts. The ones I bought have a screw to
adjust the tone as voltage effects how they sound. G.M.
www.fordcollector.com
Old 04-20-2020, 06:44 PM   #5
rotorwrench
Your 1939 likely predated the horn relay unless it's a Deluxe model. They only list them for Deluxe on the 91A-13842 relay.
Old 04-20-2020, 07:07 PM   #6
Clem Clement
thanks all. It is a non Ford horn which I removed,
Old 04-20-2020, 07:10 PM   #7
JSeery
JSeery's Avatar
Hook it up and test it. Easy to rig it up and not going to do any damage.
Old 04-20-2020, 09:48 PM   #8
Clem Clement
will do. Both test wires failed today...
Old 04-21-2020, 12:20 AM   #9
JSeery
JSeery's Avatar
Clem, how does a test wire fail? Are they melting?
Old 04-21-2020, 06:43 AM   #10
Clem Clement
old homey did wires, Taped connections instead of solder, loose clamp connections. No biggy, just annoying
Old 04-21-2020, 12:17 PM   #11
JSeery
JSeery's Avatar
Ok, I thought you were just testing it with a couple of new wires direct to the battery.
Old 04-22-2020, 09:00 PM   #12
Clem Clement
one set of wires was poorly spliced and the other the gator clasp fell off.
no biggee.
Old 09-12-2020, 01:59 PM   #13
Clem Clement
Some where I reported that the horn is working. The fuse in the voltage rheostat had a loose end and a hair line crack.
please remind me of what that thing is for?
Old 09-12-2020, 02:07 PM   #14
ford38v8
ford38v8's Avatar
They are designed to make old Ford guys ask questions.
Alan
Old 09-12-2020, 07:57 PM   #15
JSeery
JSeery's Avatar
Ok, what are you referring to as a rheostat? That term is normally used for a variable resistor, like on an adjustable dimmer switch. And which fuse? There is only one on the fuse panel. There should not be any rheostats on a 39 pickup unless someone added one somewhere. And then it should only be connected to the dash lights. Unless we are talking about a heater control switch.
Any chance you are referring to the ballast resistor?
Old 09-12-2020, 09:25 PM   #16
Clem Clement
It is about 6 inches long make of beaver board. It has a fuse and the covered coil of nichrome wire and 2 terminals. I think the metal cover is a shield from the hot wire.
PM me at Clem.clement@com and I will send a photo
Old 09-12-2020, 10:40 PM   #17
JSeery
JSeery's Avatar
That is the fuse panel and ballast resistor. The fuse is for the lighting circuits and the ballast resistor is related to the ignition coil. There is no direct connection between them except being locater close to each other.
Just happen to have one laying on my table.
Old 09-15-2020, 08:10 AM   #18
JSeery
JSeery's Avatar
Clem, see if this diagram is useful, it shows the fuse panel and the wiring.
