#1 |
This is a Diamond Block with a little flaw or is this a Big weld? I never noticed this till I rolled the engine out in the sun.
Dennis in Kelsey ca |
#2 |
I think it is the parting line between the two halves of the casting mold (cope and drag). Maybe the area was touched up with a grinder.
#3 |
I have several diamond A blocks and each one has really pronounced seams, casting lines and marks. The standard A blocks I have are a much smoother casting. Not sure if it was because the diamond was more often used in an industrial type application and not finished as smoothly or if the casting process was somehow different on the diamond blocks. Just my experience but what I have seen the diamond blocks are like that. I actually used a little jb weld to smooth out some of the flaws on the diamond I just had rebuilt.
#4 |
I think you'll find it's a casting flaw, I do alot of A engines and about all of them have that funny casting. Walt
#5 |
Might be able to tell if you removed the paint?
Paul in CT |
#6 |
This illustration shows chaplets in a vertical configuration. They are also used for horizontal alignment. ![]() |
#7 |
Just curious...what is a diamond block?
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
#8 |
Check here http://www.fordgarage.com/pages/diamondblock.htm
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 12-14-2010 at 01:08 AM. |
