08-23-2016, 07:46 PM | #1 |
1951 mercury brakes
1951 mercury has any one installed a power brake that mounts under the car with a 7" booster does it work well
08-23-2016, 11:00 PM | #2 |
Re: 1951 mercury brakes
I did, they did not work well. I had to install a reserve vacumn tank and a 8" booster to get them to work properly
08-24-2016, 06:26 AM | #3 |
Yes, I installed the under floor 7" booster and dual master setup utilizing the original drum brakes. Worked well and there is adequate vacuum.
I later converted to front disc brakes and that made the system even better. Go here to view front disc installation --- http://www.jalopyjournal.com/forum/t...lation.349439/
08-24-2016, 06:44 AM | #4 |
