Old 10-11-2021, 07:16 AM   #1
chuck stevens
chuck stevens's Avatar
Default 34 front window size
I have a 34 5 window that came with no glass, can someone tell me the right size for the front doors.
chuck stevens is offline   Reply With Quote
Old 10-11-2021, 09:39 AM   #2
T Scott
Default Re: 34 front window size
It would be very difficult to convey the glass "size" without an accurate detailed drawing since the glass has only two straight edges and the rest is compound curves. I suggest Bob's Classic Glass or any number of vendors who can supply this.
T Scott is offline   Reply With Quote
Old 10-11-2021, 09:43 AM   #3
TJ
TJ's Avatar
Check with Drake. they used to sell glass patterns. Or check with an older glass shop in your area as they may have patterns on file.
Old 10-11-2021, 10:31 PM   #4
johnboy34
Here's a picture of a 5 window door glass I saved a long time ago, it might give you an idea of what's needed.
johnboy34 is offline   Reply With Quote
Old 10-11-2021, 10:47 PM   #5
mercman from oz
mercman from oz's Avatar
Dimensions of front Window Glass for 1934 Ford Five Window Coupe, as supplied by johnboy34
Old 10-12-2021, 12:22 AM   #6
MGG
MGG's Avatar
Sanders Glass in Vancouver, Washington probably has the pattern.
MGG is offline   Reply With Quote
Old 10-16-2021, 11:37 AM   #7
johnboy34
It's pretty easy to use the car as a pattern for the front curved part of the window along with the measurements in the picture I showed you.
