06-26-2023, 09:52 AM | #1 |
37 Deluxe Coupe Floor Pans
Someone in the past had done a poor job patching the driver's side floor pan right in front of the seat at one time. The passenger side has a couple holes, but not nearly as bad as the driver side. Does anyone have any experience with these floor pans listed on Ebay or is there another supplier that I don't know about? Thanks in advance. Nate Anello
https://www.ebay.com/itm/28525435677...&segname=11304 |
06-26-2023, 10:13 AM | #2 |
Re: 37 Deluxe Coupe Floor Pans
They are made of 19 gage steel. Is that the correct thickness for your car?
Contact the company and see if they will make them for you out of a different gage thickness, if needed. |
06-28-2023, 07:01 AM | #3 |
Well, after searching for other suppliers of floor pans for my 37, I found another company,
Classic 2 Current Fabrication that sells US made pans. From the pictures, the pattern looks close. They seem to have good reviews. Since I don't have any metal shaping equipment, decided I'd give these a try. Won't need the entire piece, just a couple sections. Will report back when they arrive and after I get them welded in. Nate Anello |
06-28-2023, 01:43 PM | #4 |
I didn’t think much of the ribs in the EBay replacement floors, so I will be interested to see how your repairs turn out. The floors in my ‘37 need repair in the cowl areas and under the front seat on the right side.
06-28-2023, 01:52 PM | #5 | |
1937-1938 Ford Cabriolet Coupe & Convertible Full Length Floor Pan RH $ 150.00 | $ 162.00 1937-1938 Ford Cabriolet Coupe & Convertible Full Length Floor Pan LH $ 150.00 | $ 162.00
06-28-2023, 04:00 PM | #6 |
06-28-2023, 04:04 PM | #7 |
Yes, fix it so you can drive it.
Good Luck , Stretch |
06-28-2023, 04:57 PM | #8 |
I think the company is Livonia, MI is the eBay company. I bought a set a few years back but haven't used them yet.
