Go Back   The Ford Barn > The Archives > Early V8
Old 03-28-2005, 02:38 AM   #1
Guest
Posts: n/a
Default leaking head gaskets
just fired it up , while filling block w/h20 water started leaking out the sides , top etc . heads were surfaced , block is super clean , re torqued after hot , but still leaking . dont think any going into cyls . runs good . used a copper sandwich made by "best" ?? did notice when torqueing , the center of the gasket was oozing out sides . is this normal ? should i go to reg gaskets ? thanks
Old 03-28-2005, 03:02 AM   #2
Guest
Posts: n/a
Default Re: leaking head gaskets
1. Did you use a thread sealer on the head fasteners?
2. Did you use a sealer on the gaskets such as spray copper coat or silver/aluminum paint?
3. Did you use the Ford recommmended torque sequence and torque specs?
Old 03-28-2005, 03:08 AM   #3
Guest
Posts: n/a
What year block/motor? What year/type heads, and what material (cast iron, aluminum? Were decks also milled / surfaced? Did you check milled decks/heads for flatness? Did you use thread sealer on studs/bolts? Any type of sealant/paint used on head gaskets? How much torque on nuts/bolts are you using? John
Old 03-28-2005, 05:38 AM   #4
Guest
Posts: n/a
motor is a `40 v8 , surfaced cast heads torqued to 55 lbs ,studs, no thread sealer , used copper coat on gaskets , torqued to ford sequence cold then hot . thanks
Old 03-28-2005, 10:39 AM   #5
Guest
Posts: n/a
All but one bolt hole on each head goes to water. You need to use a thread sealer. Aviation Permatex is a good one. Generous Motors also has one they use on Caddy Northstar engines that works well.
Old 03-29-2005, 11:10 AM   #6
Guest
Posts: n/a
I suggest permatex 2 on those head bolts; stays pliable and stays on the bolts (and your hands, tools, etc... )
