Old 06-30-2023, 07:57 PM   #1
Jerry in Shasta
Jerry in Shasta's Avatar
Default crankshaft key sheared?
My roadster let out a very loud back fire and died and will not restart. I have spark, fuel, and compression.
compression #1-75 the other three 65
The only thing found is the timing pointer is about 20 degrees from where should be.
Is possible that the crankshaft key sheared?
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 06-30-2023, 08:21 PM   #2
stickshift
stickshift's Avatar
Default Re: crankshaft key sheared?
Possible, but not likely. I would start with the basics and check that the top dead center alignment with the cam gear. If good, check for something loose with the dist. When you say "timing pointer" do you mean the dist. rotor cap?
Stickshift
1915 Model T touring
1931 Ford Model AA Flatbed
stickshift is offline   Reply With Quote
Old 06-30-2023, 09:30 PM   #3
mcgarrett
Sounds like the timing gear sheared off some teeth. I would proceed as stickshift says.
Old 06-30-2023, 10:36 PM   #4
stickshift
stickshift's Avatar
That's what I was thinking...if "timing pointer" is the cam gear detent, then this is the likely cause (timing gear jumped).
Stickshift
Old 06-30-2023, 11:28 PM   #5
GeneBob
Check the condenser.
GeneBob is offline   Reply With Quote
Old 07-01-2023, 12:03 AM   #6
Richard Knight
Does the rotor turn when you step on the starter? If not, timing gear. Rotor might have moved, reset timing see if it will start. Even if it does start there still might be problem with fiber timing gear.
Richard Knight is offline   Reply With Quote
Old 07-01-2023, 06:20 AM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Assuming when he says he has spark, then he is checking the coil wire while spinning the engine with the starter. That means the distributor is still rotating, ...but out of phase.
My vote aligns with all the other's thoughts in that it has lost the timing gear. A quick check is to remove the timing gear side cover and inspect the teeth. I think you will see the issue. Be sure to remove the engine oil pan to clean the debris out of the pan as that timing gear residue has a nasty habit of plugging the oil pump in a short amount of time.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-01-2023, 06:21 PM   #8
nkaminar
nkaminar's Avatar
I will also vote for a bad timing gear.
Old 07-01-2023, 07:14 PM   #9
Synchro909
Synchro909's Avatar
I once had a rotor button that was faulty out of the box. It was too loose on the cam and moved when ever it felt like it to where ever it felt like. That was not good for smooth running!
Check the fit of rotor button on the top of the cam.
Old 07-02-2023, 06:10 AM   #10
nkaminar
nkaminar's Avatar
Good call Synchro. Now that you mention that I once had a car with a distributor that would jump out of the slot at the connection at the bottom. It would jump 180 degrees, let out a big backfire and stop. The temporary solution was always to pull up the distributor and reinsert it correctly. The final solution was to replace the worn parts.
