04-20-2016, 06:56 PM | #1 |
Steering box upgrade help
I have a 1947 upper Deluxe and I am looking to upgrade the steering box. First off I am having trouble getting the old one out. I have disconnected the steering arm, the 3 bolts that mount it to the frame ,i cut the horn wire and the losened and removed the bolt for the column clamp right at the steering box. I have turn it back and forth and even hit it with a hammer and it wont come free. I am trying to leave steering wheel and column in tact and just want to replace the steering box only. How do I get this box out and can I use a Vega steering box or what will work?
Thanks bobby |
04-20-2016, 07:16 PM | #2 |
Re: Steering box upgrade help
not sure on the 47 but my 40ish column you need to pull the steering wheel at least, cause the steering shaft has to drop out the bottom of the box. if you arent going to pull the unit this can be tricky cause you will need to jack the car up high enough to extend the shaft all the way out the bottom. this is all far easier if you just pull the entire thing.
you probably dont wanna hit that much more with a hammer either, the worm gear is sandwiched between bearing and races. if its like my column its not coming out unless you pull that steering wheel first |
04-20-2016, 07:18 PM | #3 |
You must remove the steering wheel !
04-20-2016, 07:27 PM | #4 |
rebuild the original box. Its less work them trying to make a vega box work with the stock column. Also check your king pins. With everything in tip top shape it will steer with ease
04-20-2016, 07:29 PM | #5 |
Ps. Beating on it with a hammer wont help either.41. 48 ford with the toe board removed the box will come out through the car. Done it plenty of times.
04-20-2016, 08:59 PM | #6 |
04-20-2016, 09:02 PM | #7 |
OK. so I will work on removing steering wheel tomorrow. So does the steering shaft come out with the steering box? I have the car on a lift so I have plenty of room.
04-20-2016, 09:06 PM | #8 |
Thanks for all the replies. I was just wanting to get an upgraded box as this is my fathers car and he is in his eighties and it is rough on him when in tight places trying to navigate his way out.
04-20-2016, 09:25 PM | #9 |
The shaft will come out of the box when the box is completely disassembled. The worm gear is connected to the shaft, a tight press fit. Not sure how the Vega box would make it steer much easier. If it is really a problem for him you might be better off looking at a power steering assist. There have been several threads on that topic recently.
04-20-2016, 11:04 PM | #10 |
Thanks a ton for your help. I really appreciate it
04-21-2016, 08:15 AM | #11 |
A good steering gear in a 46-8 steers very easy, at times seems line too easy. Sounds like you have other problems, when was the last time the kingpins were greased?
04-21-2016, 11:59 AM | #12 |
A shorter pitman arm might make it easier to turn the wheel when the car is not moving which is probably your issue. They make one for the Model A that is said to be work good (just saying the idea works).
Another good box is, if I remember right, from a 51 Ford pickup. Look it up on the internet and you will see the gears look like the best idea ever for a manual box, you might be able to graft it in somehow. Shorter pitman arm sounds like the quick fix and easiest. Maybe cut, weld and brace. Cutting and welding alone might not be strong enough. |
04-21-2016, 03:08 PM | #13 |
Put cross ply tires on it. Ted
04-21-2016, 06:53 PM | #14 |
Vega box is too light for a '47; if you really have to change it, use a 525 box.
04-22-2016, 08:18 AM | #15 |
The Gemmer 2 boxes are all basically the same with either side steer or cross steer being the difference. The rolling sector made them easy to steer and quite acceptable to operate. I don't understand the need to replace something that isn't broke. I would just overhaul the OEM. It may also just need new king pin bushings or tie rod ends and a new steering box won't fix that. The worm gears are usually the first thing to wear out inside a gearbox and replacements are available. Installing power steering is a complicated process for a car that has two water pumps and very little room to put a pump.
04-25-2016, 02:57 PM | #16 |
Two things: First a Vega box is too lightweight for that car. Second, it won't be easier to steer than a properly functioning original.
Rebuild the original box properly, and check the tie rod ends and kingpins. Grease everything liberally. Actually, grease everything liberally and go give it a test drive before you take it apart. Might just be that you had dry joints. If you didn't know how to remove the box, you probably aren't sure how to rebuild it either. I suggest doing some searches here on Fordbarn and following the advice to a T. |
