Old 10-04-2012, 08:41 PM   #1
Jordan
Jordan's Avatar
Default Moving back a fordor seat
Is there any way of moving back a front seat in a 1930 Murray Town Sedan? I have the seat adjusted all the way back, I still get the feeling that my knees are wrapped around my neck. So is there any way of changing up the mounts on the seats to move it back a little further?
Cowtown A's
Jordan is offline   Reply With Quote
Old 10-04-2012, 08:58 PM   #2
jkeesey
jkeesey's Avatar
Default Re: Moving back a fordor seat
Not sure if this pertains to Murray or Briggs but I did one and simple unbolted the seat and moved the seat back and bolted the front of the seat frame to what used to be the rear bolts. For the new rear location I added a piece of wood under the steel pan and screwed it to the body and bolted the rear of the seat frame to that. Worked like a charm and is now comfortably driven by a 6ft 8 man.
jkeesey is offline   Reply With Quote
Old 10-04-2012, 09:35 PM   #3
Jordan
Jordan's Avatar
Do you happen to have pictures?
Cowtown A's
Old 10-04-2012, 09:38 PM   #4
jkeesey
jkeesey's Avatar
No I didn't carry a camera at the shop back then. From what I remember the rear of the seat bracket sat flat on the topside of his floor and could easily be measured from a body crossmember to mount the board underneath.
Old 10-04-2012, 11:22 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
If I remember correctly the the rails are bolted to the seat bottom. reposition the seat on the rails by drilling new holes and moving the rails.
Old 10-05-2012, 06:33 AM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Actually, I believe what we have done is moved the mounting plate on the seat frame back. We have done a couple but I don't recall exactly but I am leaning towards the thought that there are four holes in a square pattern and you move it forwards where only two bolts are used. No need to move the tracks on the floor or seat.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-05-2012, 06:47 AM   #7
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I did as Brent says on my early 31 town sedan and it worked out well. You gain the distance of the hole spacing which is an inch or so.
Barry B./ Ma. is offline   Reply With Quote
Old 03-09-2022, 05:22 AM   #8
Ken Head
All this is good guys but the '28 & '29 fordor did not have seat rails. (IDEA) does anyone know why I / we couldn't put seat rails under my wood seat frame? I also wonder how many hundreds of guys have asked that question before I did. I I imagine they began thinking about that in late 1927. LOL
Ken Head is offline   Reply With Quote
Old 03-09-2022, 10:22 AM   #9
duke36
The average male ht. in 1920 was approx. 5'-7" or a little more; Ford was 5'-10". Perhaps they sized for an average between male/ female?
Old 03-09-2022, 09:53 PM   #10
30Murray
Remove the adjusting screw mechanism completely and you can push the seat back at least a couple more inches until it hits the floor. If that's not enough add some flat washers between the rails and the seat to raise it up a little and you can slide it back even more. Worked for me (6'3"). The rails are pretty tight so my seat will not move out of position with the adjuster removed.
30Murray is offline   Reply With Quote
Old 03-10-2022, 02:38 PM   #11
oldbird55
Call Bentleys Maysville Ga They sell seats tracks that fit the 4 door .678 407 1947 seat will move 7 in back
oldbird55 is offline   Reply With Quote
Old 03-10-2022, 02:50 PM   #12
Y-Blockhead
Y-Blockhead's Avatar
I movef the seat in my '30 Town Sedan back 3" and also bent the shifter 2" to the right so my legs would not get trapped under the steering wheel.
I agree with Duke36, people were "smaller" back then.
Old 03-11-2022, 02:13 AM   #13
ETAModel
There was a depression on, so I'm told. Groceries were a luxury.
I'm built like a fireplug, and I find it easier to back in the door of the 30 Fordor.
ETAModel is offline   Reply With Quote
