09-10-2012, 01:29 AM | #1 |
muffler question
After restoring my A, I noticed the tail pipe seems high at lines up almost exactly with the rear axle and gets exhaust residue all over. Every car Ive seen has the tail pipe lower. The car was in pieces for a number of year, so its possible the pipe got bent but I dont know how much. I was wondering if anyone knew the distance from the ground to the tail pipe (where the exhaust comes out) or any other measurements that can help me straighten it out as I am having trouble finding any. Thank you.
09-10-2012, 02:58 AM | #2 |
Re: muffler question
Who's muffler is on the car? Is the tail pipe hanger installed with the loop UP, or is it DOWN?
I have seen some of the older budget mufflers that have the pipe exit too high as your's does. |
09-10-2012, 03:06 AM | #3 |
Sagging exhaust manifold will change the aggle as well.
09-10-2012, 08:27 AM | #4 |
The "cheap" mufflers which have been around longer than I have all had a problem with this for numerous reasons. For example the header pipe is typically bent too sharp so the rear tail pipe clamp is not at the center (high point) of the arch of the tail pipe. Additionally an incorrect or unsettled rear spring raises the frame (and rear of the tail pipe) higher than normal.
Put some miles on the car with a full load of passengers (or cargo in a pickup) and it should help settle the spring and improve things a bit.
http://www.abarnyard.com/ |
09-10-2012, 09:01 AM | #5 |
You asked for some measurements. Here they are from my somewhat-pretty-much-stock 1930 coupe with a reproduction muffler purchased in December 1980 from Snake River Antique Ford Parts in Idaho Falls, ID (distances are from the floor):
Bottom of tailpipe: 6-3/4" Bottom of rear axle housing: 12-1/2" Bottom of rear cross member: 19" Other measurements: Distance between top of tailpipe and bottom of rear axle housing: ~4-3/8" Distance between end of tailpipe and centerline of rear axle housing: ~5-1/4" I don't suggest that these are factory standard measurements, just what's on my car. Others may have different measurements.
Skip Keyser Napa Valley A's Olympic Vintage Auto Club (1980-1982) MARC of San Diego (1977-1978) MAFCA (since 1978) MARC (since 1977) ---------- Model A owners belong in their Model A’s; Model A’s belong on the road. |
09-10-2012, 03:12 PM | #6 |
09-11-2012, 12:44 AM | #7 |
Measurements of my 30 coupe-floor to bottom of tailpipe-8",bottom of axle hsg 12 -1/2",bottom of rear X member 19-3/4".Cheap repro tapered muffler,taller Firestone tires.
09-11-2012, 01:04 AM | #8 |
Insert a steel pipe of slightly smaller diameter into tail pipe while muffler is bolted to frame and "bend, baby, bend!"
