09-07-2021, 09:14 PM | #1 |
1950 F3 Door window bottom rail
My door window has come loose from the bottom rail and that let's that rail bind up against the side rails. All of this needs to be rebuilt with new seals. But really don't have time for that now. I haven't tried pulling that bottom rail off but wondering if anyone has a temporary fix. Thinking of taking the bottom piece off clean it up and try to glue it to the window, maybeJB Weld? Is that too drastic? Not sure how it was held on originally.
Sent from my SM-G973U using Tapatalk |
09-08-2021, 08:35 AM | #2 |
Re: 1950 F3 Door window bottom rail
I think you need glass setting tape to attach the window to the channel. It comes in different thicknesses to match with the thickness of your window and the thickness of your channel. I would not use JB Weld for that application.
09-08-2021, 09:04 AM | #3 |
I have used black friction tape couple of layers in the past that works. Just had two driver door glass from local glass looks like a light blue silly cone. oh well.
09-08-2021, 10:08 PM | #4 |
Thanks guys! Do you know where I can get glass setting tape?
09-09-2021, 08:49 AM | #5 |
Many places have it. Probably available to you locally from an auto parts store.
Bob Drake has different thicknesses of tape and it looks like you can get it from NAPA. |
09-09-2021, 11:41 AM | #6 |
I've used silicone caulk to set the glass, but glass setting tape is better. |
09-10-2021, 09:43 PM | #7 | |
