09-07-2016, 01:38 PM | #41 |
Re: Awwe Crap!
You are obviously a WISE man! But..........you could use a long stick (stethoscope) to your ear. DD
09-07-2016, 01:44 PM | #42 |
Re: Awwe Crap!
Must be a later axle...mine doesn't look like yours.
35 Ford Cabriolet 56 Chevy Pickup 63 VW Bug Empty wallet |
09-07-2016, 01:58 PM | #43 | |
Re: Awwe Crap!
09-07-2016, 02:00 PM | #44 | |
Re: Awwe Crap!
09-07-2016, 02:06 PM | #45 |
Re: Awwe Crap!
It's a classic 37-40 axle it has 39-40 brakes so was probably chosen as a direct bolt in replacement. If it has wide 5 hubs it could be a 39 axle with it's original hubs. One thing is for sure, it makes for a very neat conversion to hydraulics when it comes to running the pipes etc.
I'm lazy. There was nothing bothering you about the axle before something went pop. I'd just concentrate on replacing the component that broke and putting everything else back together exactly as it was removed. Chances are the bearings are better quality than a new replacement. There is no good reason to remove the pinion, why risk damaging the housing (which can happen if not done correctly) just for the sake of removing it because you feel you should. Edit: ha ha just saw the wires. 40-48 hubs, which hopefully should have a support ring to support the inside diameter of the wheel face. Mart. |
09-07-2016, 02:16 PM | #46 |
Re: Awwe Crap!
09-07-2016, 02:21 PM | #47 |
Re: Awwe Crap!
It looks like a nice neat installation in a pretty nice car.
09-07-2016, 02:22 PM | #48 | |
Re: Awwe Crap!
There was absolutely no problems with the rear end before yesterday. Did the Dream Cruise several weeks ago and that's nothing but stop and go. Had the car up to highway speed last weekend...no noises whatsoever from the rear. Never any clunking...etc. Yesterday took me completely by surprise.
09-07-2016, 02:25 PM | #49 |
Re: Awwe Crap!
Thanks...I guess I won't send it to the crusher after all...
09-07-2016, 02:27 PM | #50 |
Re: Awwe Crap!
I see on the Van Pelt site that a 35-38 axle has 18 teeth and a 39-41 has 16 teeth. Guess that means I need to take it apart to find out what tooth count I have.
09-07-2016, 02:45 PM | #51 | |
Re: Awwe Crap!
I think you must have been mistaken about hearing the noise while in neutral. Nothing rotates past the transmission while in neutral unless the car is rolling.
Alan |
09-07-2016, 03:06 PM | #52 |
Re: Awwe Crap!
38V8 I don't know how to quote just one sentence of a previous post but I think you'll know what part of your post I'm taking about.
I know that nothing is supposed to rotate behind the transmission when it's in neutral but I seem to remember in my past working on a more modern vehicle that when I started it without a driveline on and in neutral, the yoke was turning due to the lube inside. I could reach up and grab the yoke and make it stop...thought something similar could be happening here. I have some jockeying around of vehicles to do when I get home in order to get the 35 where I want to work on it. I'll put a jack under it and give that axle a tug and see what happens. I'll loosen the brakes if I need to.
09-07-2016, 03:22 PM | #53 |
Re: Awwe Crap!
Yes, that is true, but nothing was connected to that yoke. In this case, the transmission output is connected all the way through to the wheels.
Alan |
09-07-2016, 03:28 PM | #54 |
Re: Awwe Crap!
If an axle is broken isn't the driveline free to rotate?
09-07-2016, 03:39 PM | #55 |
Re: Awwe Crap!
Yup, ya need to count teeth. One more distinct possibility to be aware of when you get it apart-enough to fondle an axle shaft. You need to also measure the length of your axle shaft to make sure it's a '37-'41. I say this only because it is POSSIBLE that someone has installed a '42-'48 rear end assembly with a '37-'41 drive shaft, torque tube and radius rods. As you noted, the '37-'41 axle shaft will measure 32.85", and could have either 18 OR 16 teeth. A '42-'48 rear end assembly is only slightly wider overall, and COULD be installed. '42-'48 axle shafts all measure 33.70" and have 16 teeth, which mate with 11-tooth spider gears. Just a "heads-up" so you know which axle to look for with certainty. DD
09-07-2016, 04:22 PM | #56 |
Re: Awwe Crap!
I'm home and have discovered the problem. Before I share that, I feel VERY lucky that this didn't turn out WAY worse...I think my dad was looking down on me! Yep, it's a broken left side axle. I jacked the car up, tugged on the wheel and it fell off in my hand. I pushed that car around a corner from where it broke...down the street 1/2 block and a 90 degree turn into my driveway.
09-07-2016, 04:30 PM | #57 |
Re: Awwe Crap!
Did you disconnect the hand brake or was it already that way.
Bob |
09-07-2016, 04:34 PM | #58 | |
Re: Awwe Crap!
Also, with the hub installed on a good axle, does the hub put a little tension on the axle to keep the gear end of the axle up snug against the spider carrier? I hope the answer is yes...if not, I may have more problems inside.
09-07-2016, 04:50 PM | #59 |
Re: Awwe Crap!
There should be very little movement in & out of the axle. If there is movement something is wrong (other than the obvious brake at the end).
09-07-2016, 05:07 PM | #60 |
Re: Awwe Crap!
It was that way...I left it like that when I restored the car. I have an original e-brake handle that was intended for mechanical brakes and I have no way to go from the original handle to the cable so I put a big spring at the point of the cable V just to hold it up. I didn't want that spring to apply brake pressure so I left them disconnected in the drums. Once I figure out how to go from the e brake lever to the cable, I'll hook them back up. At least I have all the cable parts where they belong until I can get the rest figured out.
