10-06-2019, 11:53 PM | #21 |
Re: vibration in my car
Raise one right front wheel off the ground, grab wheel by 9 and 3 o'clock and see if there is a lot of movement. Take a look at the Idler Arm to determine if the rubber bushings are kaput. Tell me what you find out.
10-07-2019, 03:56 AM | #22 | |
All bushings (idler arm - control arm - PS linkage) must be good. For example if outer tie rods are bad, you will get a front end vibration usually around forty to fifty miles and hour. If vibration is felt in steering wheel, it is usually front related. Vibration in seat of pants, drive-line vibration. Much less, with a loose front end, there is no way the front end can be aligned.
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
10-07-2019, 11:35 AM | #23 | ||
If the wheel spins true but the tire & wheel together wobble when they're off of the car, the tire is the culprit. . Last edited by dmsfrr; 10-07-2019 at 08:16 PM. |
10-07-2019, 03:01 PM | #24 |
O. M. G.
What does this printed word read on my RF Drum? The shaking side? |
10-07-2019, 05:50 PM | #25 | |
If the drum is actually bent and will not sit on the hub correctly, that may be the cause of what you saw wobbling. It pushed the wheel out of line.
10-07-2019, 06:14 PM | #26 |
10-07-2019, 07:08 PM | #27 |
Yep looks like paint stick wrecking yards used.
10-11-2019, 11:47 AM | #28 |
Swap the tires around, back to front and see how it rides. Where do you feel the vibration? Steering wheel, brake pedal??
10-11-2019, 02:24 PM | #29 |
hat's what i've done,and it's the same thing....
10-11-2019, 03:44 PM | #30 | |
If at speed, if you put it into neutral, does the vibration subside? Does it do it under power and/or coast?
10-11-2019, 05:21 PM | #31 |
Open the hood engine operating in park, position the throttle at cruise speed, does engine shake?
10-12-2019, 05:54 AM | #32 |
both...
10-12-2019, 07:00 PM | #33 |
I had a Ford with a driveshaft that was made up of two parts with rubber in the center, anyhow the shaft had come out of faze ever so slightly causing the vibration. My fix was to have a new one peice shaft made and vibration was gone.
