11-09-2022, 05:56 AM | #1 |
Fender rubbers
On the rear of the front fenders of the 46-48 fords & mercury where they bolt to the cowl there is 4 heavy duty rubber washers that go on the bolts & have a nipple that fits into the large hole in the fender.. I have tried everyone with no luck on finding them, has anyone with these cars had any luck in finding them,
Thanks, Rick |
11-09-2022, 10:07 AM | #2 |
Re: Fender rubbers
Did you check with Michael at Third Gen Automotive?
11-09-2022, 05:15 PM | #3 |
Re: Fender rubbers
Yes I did, thank you
11-09-2022, 05:44 PM | #4 |
Re: Fender rubbers
11-09-2022, 09:56 PM | #5 |
Re: Fender rubbers
Seth, they did not, I also spoke to Fred at I believe is obsolete & I spoke to Joe at Joes antique parts and no one is familiar with these rubber washers. I know they use to be available because I have purchased them in the past . Thank you. Rick
11-09-2022, 10:19 PM | #6 |
Re: Fender rubbers
11-10-2022, 06:31 AM | #7 |
Re: Fender rubbers
Thanks will try
11-10-2022, 11:14 PM | #8 |
Re: Fender rubbers
I remember using them on our '41. believe I got them from Macs but was years ago. I needed some more and rather than buying them I bought a rubber sheet from Mcmaster-Carr suply and punched out my own. Didn't have raised portion but worked OK. Used a flat washer the same diam. as the rubber and they formed into the hole in the fender nicely.
11-11-2022, 05:26 AM | #9 |
Re: Fender rubbers
Thanks fordor41, thanks, I have purchased them in past, must be to small an item to reproduce.
11-11-2022, 07:53 AM | #10 |
Re: Fender rubbers
Rick check with Butch, Straightpipes on this forum.
11-11-2022, 10:42 AM | #11 |
Re: Fender rubbers
Will do Bob, thanks
11-11-2022, 11:04 AM | #12 |
Re: Fender rubbers
Do you have a photo of what they look like?
11-11-2022, 12:50 PM | #13 |
Re: Fender rubbers
Yes but can’t seem to get it to post.
11-11-2022, 05:30 PM | #14 |
Re: Fender rubbers
Can you send photo in private messages?
11-11-2022, 08:19 PM | #15 |
Re: Fender rubbers
I poked my head under my '46 Ford wagon and it looks like about 1/4" thick by about an inch or so. If you can not locate one I would do as fordor41 recommends and purchase the rubber from McMaster-Carr and use a hole punch and you're done.
11-12-2022, 06:02 AM | #16 |
Re: Fender rubbers
Woodiewagon46, yes that would work except the fenders have large holes approx 1/2” so the nipple on the back side of these rubber washers will fit into them, that is the problem with just using a flat piece but thank you for your time & input.
11-12-2022, 08:01 AM | #17 |
Re: Fender rubbers
11-12-2022, 12:47 PM | #18 |
Re: Fender rubbers
Thank you, sent pictures
11-12-2022, 04:37 PM | #19 |
Re: Fender rubbers
11-12-2022, 05:39 PM | #20 |
Re: Fender rubbers
Thanks neighbor for pictures
