08-15-2015, 04:40 PM | #1 |
carb questions
Hi All,
I just bought a Marvel Schebler carb as an experiment to see how it would run on my car vs. the Zenith. Well I took it apart and started cleaning it up yesterday and realized she is in really pretty good shape. the main jet cleaned up really nicely on the wheel but how do I clean the inside out of the jet out? I know it is .113 but I can see some crud from 50 yrs of gas in it. Soak it/ scrub it? I also measured the throttle valve shaft and where the wear is she measured .276 if I remember right and .278 on the non wear spot. Is that worth dealing with? Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
08-15-2015, 05:42 PM | #2 |
Re: carb questions
Soak it in carb cleaner and then blow it out with compressed air.
08-16-2015, 05:11 AM | #3 |
Re: carb questions
Try Evinrude carb cleaner from outboard store.
08-16-2015, 03:29 PM | #4 |
Re: carb questions
