08-17-2019, 02:16 PM | #1 |
Sanity check on lubing springs in place
I want to try to improve ride and correct a slight lean by lubricating the springs without removing them. I know the "right" way is to take the springs out and check them, but I don't want to spend the time/money.
Since I haven't done this before, I was hoping somebody could take a look at this planned sequence and tell me if I'm missing anything or creating problems. I'm planning to do the whole sequence once for the front springs and once for the rear.
Does this look OK? Any improvements? |
08-17-2019, 02:21 PM | #2 |
Re: Sanity check on lubing springs in place
Where is the containment step in your sequence? C-clamps, or logging chain would do the job. I would do with step 4.
08-17-2019, 02:42 PM | #3 |
08-17-2019, 02:47 PM | #4 |
Don't take the springs apart.
> Have someone rock the car side-to-side and spray the springs on both sides with SAE 10 oil. Do this a few times after driving the car; > Buy a set of spring covers and saturate the felt pads with 140 gear oil. Install the pads, and annually replenish the gear oil. An immediate ride improvement can be had by reducing the rear tire pressures to 28 psig, and the front tire pressures to 30 psig.
Bob Bidonde |
08-17-2019, 03:09 PM | #5 |
There may be some confusion, I'm not planning to disassemble the springs. I'm just trying to lift the frame away from them slightly so that I can get up as close as possible to spray them with the lubricant. They're not coming off the axles.
I know there's a lot of cautionary tales out there about the stored energy in the springs, hence the recommendation of a spreader for the rear springs. What I'm trying to figure out is, am I OK just lifting the frame off them briefly without the spreader? Or do I need to do the lubrication with the frame in place, per Bob Bidonde's suggestion? |
08-17-2019, 03:22 PM | #6 |
08-17-2019, 03:25 PM | #7 |
OK, so that is now two votes for "don't take the U-bolts off." Good to know.
08-17-2019, 03:44 PM | #8 |
The center bolt can fail at any time, the best time would be when the spring is contained.
08-17-2019, 03:55 PM | #9 |
Sounds like I should just eliminate step #4, and in step #7 just tighten the hanger nuts, make sure they're even.
08-17-2019, 04:44 PM | #10 |
Alex,
Why all the work ?? 1. Jack up the car placing jack stands under the front motor mounts. 2. Remove front wheels. 3. Lower the front axle until the shocks bottom out. 4. Soak the relaxed leaves with your favorite penetrating oil. 5. Jack her up & reinstall front wheels. I used the same product, worked great for me. JB |
08-17-2019, 04:47 PM | #11 |
I like this method, guess I should decide whether it's more work to take the wheels off or just to jack the frame up another foot, seems like it would have the same effect.
08-17-2019, 05:21 PM | #12 |
Be Very careful of the springs! I'm sure that in the history of model A s, someone has been killed by the rear spring. I almost lost a leg to one. DO NOT LOOSEN the SPRING UNLESS YOU HAVE IT CONTAINED!
To return to the subject at hand, here's what I would do; With the body in place, loosen the center nut on the spring. Back it off no more than two turns. Now flood the little gaps between the leaves with motor oil in a squeeze can.Maybe jack the frame (not the wheels) a click or three and get as much oil in between the leaves as is possible. Then let it all down on the ground again and retighten the center bolt of the spring. This is far easier and less dangerous than messing around with the spring. Terry Last edited by Terry, NJ; 08-18-2019 at 11:52 AM. |
08-17-2019, 07:03 PM | #13 |
How about using one of these gizmos.
08-17-2019, 07:13 PM | #14 |
Not familiar with that gizmo, what is it?
08-17-2019, 07:24 PM | #15 |
I just jack one end of the car at a time up high, enough so that jackstands under the frame will let the wheels and spring hang as far down as it’ll go. Then I use like a motorcycle chain lube or Teflon silicone, or a penetrating type oil squirted all around the leaves.
08-17-2019, 08:06 PM | #16 |
I use a simplified method--- take oil can, fill with atf, squirt on springs. Go for drive---- don't forget the oil hole in the hand crank bearing
08-17-2019, 09:14 PM | #17 |
Penephite is designed to travel horizontally.
08-17-2019, 09:31 PM | #18 |
08-17-2019, 09:56 PM | #19 |
I'd just put some old motor oil in a squirt bottle, spray the spring packs and take it for a ride. Come home and wipe up any mess.
I had my rear spring apart The leaves don't relax until you remove the center bolt and start loosening the clamps. |
08-17-2019, 11:01 PM | #20 |
