Old 02-14-2024, 11:56 AM   #41
Jim Brierley
Default Re: Model A cam ground to "B" profile
Originally Posted by ModelA29 View Post
MARC has the stock spec for the A & B cam on their site: https://model-a-ford.org/top-page-1/...pecifications/
Those specs show only the very latest of the B grinds, the most common B had .302" of lobe lift. The one shown makes a vey good touring cam.
Jim Brierley is offline   Reply With Quote
Old 02-14-2024, 11:57 AM   #42
Jim Brierley
Originally Posted by Dan McEachern View Post
ok you guys! knock it off!
Just trying to be factual!
Old 02-14-2024, 06:48 PM   #43
Pete
Pete's Avatar
Be sure you know what B grind you have. Is it an OEM original grind or an after market
re-grind? It makes a difference.
Original's were designed and made with a whole different math program.
Mixing grinds and lifter face diameters is NOT a good plan.
Another thing to remember, original OEM lifters were faced FLAT.
Most modern ones are tapered.
Old 02-16-2024, 02:23 PM   #44
Dan McEachern
Originally Posted by Jim Brierley View Post
Pete, I don't know any good cam grinders, do you???
Jim- I was referring to this-
Dan
Dan McEachern is offline   Reply With Quote
Old 02-20-2024, 07:52 AM   #45
nkaminar
nkaminar's Avatar
I think that Formula 1 racing cars are now using pneumatic operated valves that are controlled by a computer. That means the timing is variable and that the valves lift and seat quickly. The timing can be tweaked while the engine is on the dyno to get the most torque at each engine speed. And even tweaked for each race course. The race course in simulated in a computer.
I wonder what AI could do?
Old 02-20-2024, 08:08 AM   #46
johnneilson
pneumatic springs have been around for some time now, still opened by cams.
variable cam timing has also been around for some time, is in many production cars today.
I read years ago about electromagnetic valve actuation experiments. Not sure it has made it to the track yet.
Personally I like the older desmodronic valve setup.
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 02-20-2024, 10:45 AM   #47
Benson
Benson's Avatar
My 2002 Toyota Highlander uses engine oil pressure controlled by the computer to vary the valve timing of the DOHC camshafts.
Gives you the "low end grunt" of one valve timing profile AND the higher RPM power of a different profile in same engine.
System is called VVT Variable Valve Timing. Introduced in 1995.
Benson is offline   Reply With Quote
Old 02-20-2024, 12:19 PM   #48
Phil Brown
Phil Brown's Avatar
https://youtu.be/iM5Tl_oytMM?si=5rH7l7v5Dihf0Dfd
If you have never seen a cam get ground kinda interesting video
not model A but it shows the machine and how it grinds the lobes to shape and there placement relative to each other
Phil Brown is offline   Reply With Quote
Old 02-20-2024, 05:14 PM   #49
Pete
Pete's Avatar
Personally I like the older desmodronic valve setup.J
Here is a video of a Renault F1 engine on the dyno. This engine used the EM valve system. This pull is programmed to simulate a lap on the track. The glow outside the fuel flow above the injectors is plasma caused by the high speed air flow.
The engine is peaking at 21000 rpm.
https://youtu.be/y2iBbwocYZw
Old 02-20-2024, 08:08 PM   #50
johnneilson
Uh, no,
bridge property for sale, cheap!!
J
