02-07-2024, 07:26 PM | #21 |
Re: Model A cam ground to "B" profile
Would your C cam or a Burtz cam and a 6:1 head need more carb than a Tilly? I like the stock carb linkage.
02-08-2024, 07:06 AM | #22 |
If you like the original linkage, try two Tilly's with a double updraft manifold. One stock carburetor and manifold really restricts airflow at anything above 1,500 rpm.
02-08-2024, 02:04 PM | #23 | |
Should have been "to raise compression and install a bigger carb". Thanks jeepguy, My mind isn't as sharp as it used to be. |
02-08-2024, 02:09 PM | #24 | |
02-09-2024, 12:14 AM | #25 |
Mine (memory) isn’t so great either, what were we talking about?
02-09-2024, 05:59 AM | #26 |
02-09-2024, 12:05 PM | #27 |
Here is a cam question that is not exactly what started this thread but I think it is close enough: I recently bought a B motor that was rebuilt some years back that has a “High Lift” cam in it. Unfortunately all paperwork has been lost and the seller (elderly, grumpy) has no idea what it really is. Nobody needs to tell me what “High Lift” means but I know it doesn’t mean much. I know how I can measure lift but not duration. Is there a way to determine what this cam really is? I’m tempted to just yank it out and put in one of Jim’s. I don’t like not knowing what I have. The engine has not been fired yet and probably won’t be for while.
02-09-2024, 12:35 PM | #28 |
02-09-2024, 01:21 PM | #29 |
Hmmm
So I just had this conversation this week with a friend He sent me some timing specs that he measured Of the timing specs only the 050 numbers made any sense Even after discussing the duration at 050 I asked him what vehicle it was going in He said nothing right now but wanted to know Ok so this information is only a small component in the overall motor and performance Yes it is nice to know but without actually running the motor on a dyno or in a car it is insignificant Something that really impacts the motor characteristics is the cam timing and lobe cl One can be changed pretty easily the other not so much If you need a name and grind number buy a cam from Jim J
As Carroll Smith wrote; All Failures are Human in Origin. |
02-11-2024, 01:40 PM | #30 |
You can get an idea by putting a degree wheel on the crank and marking the degrees when the valve starts to lift, and when it hits the seat after going thru it's cycle. This is fairly accurate but not as much as when done in a cam doctor or in a lathe with a degreed chuck.
02-11-2024, 03:52 PM | #31 | |
02-11-2024, 09:49 PM | #32 |
John, I have purchased 2 cylinder heads and 1 cam from Jim and am not adverse to buying another but I don’t have enough money to be stupid with it. Also, half the questions I ask on the forum are because I am curious and trying to learn.
02-12-2024, 11:33 AM | #33 |
Jeep
Let me ask you a question Do you salt and pepper a steak at a restaurant before tasting? Don’t get me wrong asking questions is great, the secret to racing is to ask questions The secret to going fast is to ask the right questions I have made a few cams and worked with a few grinders over the years I can make some pretty good estimations of where to start with a cam but I use data and run the motors to make decisions about the package I also use some pretty extensive software in comparison to determine where to start So to ask, what is the measured lift of the existing cam? And is it a large journal cam? J
02-12-2024, 12:43 PM | #34 |
02-12-2024, 01:05 PM | #35 |
02-13-2024, 01:07 PM | #36 |
- Me too!
02-13-2024, 06:47 PM | #37 |
ok you guys! knock it off!
02-13-2024, 07:32 PM | #38 |
MARC has the stock spec for the A & B cam on their site: https://model-a-ford.org/top-page-1/...pecifications/
02-14-2024, 10:21 AM | #39 |
Hello, doesn’t the B cam have different cam followers, lifters than Model A , thought the base of B cam followers, have a larger diameter?
02-14-2024, 10:56 AM | #40 | |
https://www.fordbarn.com/forum/showthread.php?t=331692 |
