Old 01-08-2018, 01:40 AM   #21
Dollar Bill
Dollar Bill's Avatar
Default Re: Zenith carburetor paint
Originally Posted by Tom Endy View Post
Several have suggested Por-15. I used this product on several Zenith carburetors a number of years ago. It does not hold up well against fuel and constant heat cycling. When first applied it gives the carburetor a plastic look. After a few years of service it will begin to peel off like a bad sunburn. See photo. Tom Endy
The POR-15 failed because there was some other paint beneath it. Surface preparation for POR-15 requires degreasing and phosphoric acid bath - No primer. POR-15 adheres best to a rusty surface; seasoned metal and sandblasted surfaces are also acceptable.
From the POR-15 web site - "POR-15 works because it chemically bonds to rusted metal and forms a rock- hard, non-porous coating that won't crack, chip, or peel. It keeps moisture away from metal with a coating that is strengthened by continued exposure to moisture"
The only caution for POR-15 is that it must be top coated if exposed to UV.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 01-08-2018, 03:18 AM   #22
Mike V. Florida
Mike V. Florida's Avatar
You can always try this way;
Japan Black recipe
Or get it already mixed;
Japan black already mixed
Old 01-08-2018, 07:44 AM   #23
Reconnoiter
KG Gun Kote -Satin Black 2401S
Impervious to fuel, looks great, extremely durable.
Airbrush it on...
http://www.kgcoatings.com/products/p...eries-gun-kote
File Type: jpeg AE3A84D5-67E5-4CB1-A2D5-B3EE8D99F2FC.jpeg (68.0 KB, 56 views)
Reconnoiter is offline   Reply With Quote
Old 01-08-2018, 02:12 PM   #24
Purdy Swoft
Purdy Swoft's Avatar
My thanks to all that responded to this post with suggestions. In particular, D.J. Moordigan who suggested a company called Brodak. I contacted then and have ordered a small container of their fuel resistant black paint.
Tom Endy
Read post 21 !!! What Dollar Bill says hits the nail on the head . It was very obvious to me when I saw the picture . If a person can't follow the supplied instructions , to the letter , Its best not to use the product . Any type finish will fail without proper surface prep as well .
Old 01-08-2018, 04:32 PM   #25
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Use ca use AERO GLOSS Flat Black, found in most hobby stores
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 01-09-2018, 06:06 AM   #26
RonC
RonC's Avatar
Epoxy paint is forever. The trick is to find a quality semi gloss black epoxy.
RonC is offline   Reply With Quote
Old 01-09-2018, 04:51 PM   #27
Tom Endy
Tom Endy's Avatar
My thanks again to D. J. Moordigan, post #12. I ordered a can of black fuel proof paint from Brodak. It is a dull black and is certainly fuel proof. I dipped the head of a bead blasted bolt in the paint and let it sit overnight. I then submerged it in gasoline for several hours. The paint remained unaffected.
I also obtained a can of similar paint from Sig mfg Co. It is a gloss black and is also fool proof as I subjected to the same bolt test.
Both companies have a web site. Brodak is located in Pennsylvania and had no trouble shipping to me in California.
Both paints are called a Butyrate dope.
Brodak is dull black
Sig is gloss black
See the attached.
Tom Endy
Tom Endy is online now   Reply With Quote
Old 01-09-2018, 05:19 PM   #28
30ccpickup
30ccpickup's Avatar
Sig is gloss black
See the attached.
Tom Endy
Thanks Tom for the thread and the follow up.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 01-09-2018, 05:37 PM   #29
Larry Jenkins
Read Post Number 10. The best.
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 01-09-2018, 06:08 PM   #30
Jim Mason
Jim Mason's Avatar
The Pontypool japan black is the high gloss version of 'Japan black'. this may be closest to the version used to flow paint Model T's. You may be able to add rosin to it to flatten the finish to be close to the carb paint desired
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 01-09-2018, 09:50 PM   #31
Mikeinnj
Mikeinnj's Avatar
Japan Black recipe
Corn gas will destroy Japan Black.
Mikeinnj is offline   Reply With Quote
Old 01-10-2018, 05:34 PM   #32
4port
4port's Avatar
Brodak's dope is made by Randolph Products. I get mine from Wick's Aircraft Supply. Aircraft Spuce and Specialty is another supplier of Randolph dope.
Cheapest by the gallon. AeroGloss a Pactra product is no longer available, bought out by Midwest Products. Been building R/C models for years.
Remember when flying low inverted, down is up, and up can be expensive.
4port is offline   Reply With Quote
Old 01-10-2018, 09:45 PM   #33
henry's 31
I use black Rust Oleum Engine paint. Gasoline resistant, great color, very lasting. I paint all my carburetors with this.
Henry' s 31
henry's 31 is offline   Reply With Quote
