Old 06-04-2019, 02:06 PM   #1
Werner
Werner's Avatar
Default Heater hose connection
Hello, what do you use for the hose connection between exhaust heater and heater door flange on the firewall? I hade used a concertina tube made of aluminum, that was only 500 ml airtight and is now torn through.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 06-04-2019, 03:01 PM   #2
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Default Re: Heater hose connection
For years members in our club simply use a cut up pop can. Roll it up, shove it in and let it expand.
Jacksonlll is offline   Reply With Quote
Old 06-04-2019, 04:20 PM   #3
Werner
Werner's Avatar
Jackson, please tell me what is a "cut up pop can"?
Werner
Citroen 11 CV, 1947
Old 06-04-2019, 05:17 PM   #4
1931 flamingo
1931 flamingo's Avatar
I'm betting a soda pop (Coca-Cola, etc) with both ends removed and then split lengthwise.
Paul in CT
Old 06-04-2019, 07:58 PM   #5
Jacksonlll
Jacksonlll's Avatar
That’s it Paul.
Old 06-04-2019, 09:52 PM   #6
CarlG
CarlG's Avatar
Perfect for this application is SCAT hose, available from your local aircraft supply. Aircraft Spruce will sell short lengths in multiple sizes. It's made for hi-temp applications.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-05-2019, 08:43 AM   #7
Ray in La Mesa
I used one of the small 5.5 oz. juice cans, V8, pineapple grapefruit apple, etc.
Ray in La Mesa is offline   Reply With Quote
Old 06-05-2019, 05:34 PM   #8
taffrail
taffrail's Avatar
Roofing flashing, cut to depth, roll up, insert it from the firewall door and let it unwind.
Remove with with needle nose pliers. If you screw it up no problem, make another one.
taffrail is offline   Reply With Quote
Old 06-06-2019, 04:38 PM   #9
Werner
Werner's Avatar
The suggestion with the lime bottle is theoretically good. But in Germany this does not work, because other plastic is used. When heated, the hose shrinks. I will therefore try the suggestion of Carl.
Werner
Citroen 11 CV, 1947
Old 06-07-2019, 05:13 PM   #10
Werner
Werner's Avatar
Today I mounted a SCAT-tube from an airplane. I will report how it works over a long time.
Thanks for all informations!
Werner
Citroen 11 CV, 1947
Old 06-07-2019, 05:35 PM   #11
daren007
Scatt. The amount needed is too small for aircraft use. Check your local aircraft maintenance facility. They usually throw out pieces this short.
daren007 is offline   Reply With Quote
