07-12-2015, 06:05 PM | #1 |
Blueprint of model B' valve cover; dimentions?
Does anyone out there have access to a drawing of all the hole locations and measurements of a B' valve cover? Rather than buy a poorly sand cast-finned version of one, I want to machine mine from a solid piece of aluminum and make it unique to my own engine. Thanks in advance, Steve
07-12-2015, 06:26 PM | #2 |
Re: Blueprint of model B' valve cover; dimentions?
Take the dimensions from your B block!
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
07-13-2015, 11:51 AM | #3 |
or use the stock cover as a jig.
07-13-2015, 12:52 PM | #4 |
My direction would be to contact Bensen Library and purchase a copy of the B-6520 print.
07-13-2015, 04:22 PM | #5 |
Or just purchase a Model B valve cover gasket. For sure much quicker and cheaper.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
07-14-2015, 12:45 PM | #6 |
07-14-2015, 05:05 PM | #7 | |
That places the assumption the gasket is properly sized. Your point does have merit by using transfer punches to get something to work, ...and that may be all Steve is interested in doing. A saying we sometimes use here at the shop is 'It doesn't need to be Perfect when Good is good enough!'. |
07-14-2015, 05:30 PM | #8 |
I have lots of stock ones for $25 each if you need one.
Steve @ Bert's Model A Center |
