11-08-2021, 09:24 PM | #1 |
Merc crank clean out plugs
Hey guys, so I told the guy I needed a tap and a plug for a 5/8 hole, this is what I got,
Is the correct tap and plug size ? Thanks .. |
11-08-2021, 09:52 PM | #2 |
Re: Merc crank clean out plugs
Not by my standards. 3/8" and 5/8" are 1/4" apart in size. Perhaps someone misunderstand.
11-08-2021, 10:04 PM | #3 |
The nominal OD of a 3/8" pipe is 0.675" and the tap drill size for 3/8" NPT threads is 37/64", so the 3/8" pipe plugs might work for your application.
11-08-2021, 10:23 PM | #4 |
I pretty much get all this, but without going down to the shop, did the 4" crank use some kind of press in plugs originally? Won't these threaded plugs change the balance? I have a recently turned merc crank and it came back witout plugs and IIRC it's up to me to clean out the chips. I think threaded plugs would be more secure. Keep up the discussion on the drill/tap/plug combination and I will assume an allen head type pipe plug. Thanks!
11-08-2021, 11:17 PM | #5 |
Nothing wrong with the proper press in plug. They've lasted for at least 70 years in these engines.
11-08-2021, 11:52 PM | #6 |
11-09-2021, 12:54 AM | #7 |
When I did my Merc.crank I ordered the plugs from Summit nice alum.plugs.Cliff.
11-09-2021, 01:46 AM | #8 |
I made them from soft aluminum on my lathe.
11-09-2021, 08:06 AM | #9 |
I got brass ones on amazon. Came in a set of 5. I used the 5th one for the hole behind the cam gear. For some reason or other the chinese cast iron ones from the hardware store did not fit but the brass ones went in nicely. One has slightly better tolerances I guess or it is the tap I had. Either way the cast iron ones are a hare bigger.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
11-09-2021, 03:22 PM | #10 |
Yes,,,,3/8 pipe thread is the correct size for Merc clean out hole .
Just take your time with the tap,,,,,these cranks are fairly hard . Tap a little and clean out shavings some,,,,,it’s not too hard,,,just make sure to tap deep enough for the plug to screw in pretty flush . I like to use Tap Magic for lube,,,it taps better . Or use stock type cup plugs,,,they work fine as well . Tommy |
11-09-2021, 03:53 PM | #11 |
And I will assume some loctite whichever route I choose?
11-09-2021, 04:31 PM | #12 |
Just for info.... the 'cup-type' plugs that I have, came from Dorman. Available at my local parts store. Seems to me, they look same as original factory plugs. (for me, press in, no loctite. But, I see no reason that loctite would hurt.)
11-09-2021, 04:45 PM | #13 |
Considering that Ford used the drive in plugs for millions of miles with no issues (known to me)
I chose to use the Dorman 555-010 plugs. No Loc-tite, drive in, 3-4 stake marks.
