03-19-2023, 02:57 PM | #1 |
Ford Carb for flathead ID
On the carb it says Ford
There is a 1 1/16 and a model EC Does this carb give good fuel volume or will it put down the road @ 45? Is it a 48 81 or 97 or? I am looking for the most get for the go using a stock 32 Ford engine with single exhaust. I will change the intake but it will still be single carb. Thank you |
03-19-2023, 03:00 PM | #2 |
Re: Ford Carb for flathead ID
It is a Ford /Holley 2V for mid 50s y-blocks. A bit larger than the standard 94. It isn’t an81,97, or 48. Those are strombergs.
I dig coal, which provides motivation for EVs. |
03-19-2023, 03:03 PM | #3 |
The EC was a mid 50s Y-block Ford/Holley model. It is a big bigger than the 94. The 81, 97, 48 models were Strombergs.
Hmm, first reply didn’t show up right away.
03-19-2023, 06:48 PM | #4 | |
Sal |
03-19-2023, 08:12 PM | #5 |
