Old 12-04-2019, 07:06 PM   #1
Russ/40
Russ/40's Avatar
Default Can you help with this? Tool related
Can anyone tell me where to find the "mandrel" for this type roloc?
Old 12-04-2019, 09:44 PM   #2
rogerkb1936
rogerkb1936's Avatar
Default Re: Can you help with this? Tool related
they were made by 3M years ago. maybe they are still available from them. I used to use them a lot with good results
rogerkb1936 is offline   Reply With Quote
Old 12-05-2019, 01:06 AM   #3
Russ/40
Russ/40's Avatar
I have acquired a large quantity of the older type, but have not been able to find a mandrel to be able to use them.
Old 12-05-2019, 01:06 AM   #4
CarlG
CarlG's Avatar
Google “3M Roloc Mandrel”. Came up with a lot of hits.
Back when I was still working, I bought them from industrial hardware store or aircraft supply houses.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-05-2019, 12:56 PM   #5
Bob C
Is this it? https://www.ebay.com/itm/3M-1-4-in-x...kAAOSw4RZbEKlh
Old 12-05-2019, 01:14 PM   #6
Beater
Beater's Avatar
looks easy enough to make actually
Beater is offline   Reply With Quote
Old 12-05-2019, 01:55 PM   #7
Vin-tin
Vin-tin's Avatar
Originally Posted by Bob C View Post
I think that's the one. Grainger might have them also.
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 12-05-2019, 03:45 PM   #8
d.j. moordigian
d.j. moordigian's Avatar
No. The mandrel screwed into a rubber and metal unit,..similar too this.
You have to have this to make it work correctly.
https://www.grainger.com/product/52J...QYCSABEgLXwfD_
d.j. moordigian is offline   Reply With Quote
Old 12-05-2019, 04:59 PM   #9
Bob C
OK, how about this. https://www.amazon.com/Medium-3M-Rol...JEW39S79D254YG
Old 12-05-2019, 05:42 PM   #10
Big hammer
There you go!!
get a bigger hammer tap done
Old 12-05-2019, 06:40 PM   #11
Russ/40
Russ/40's Avatar
Bob C, I think that is it. Apparently there are two or three sizes for diff size discs. Also, i don't see any way to back up the discs. Bob C's photo might be for that, but it doesn't look like it to me. RogerKB1936, what do you think of the ones in post #9. Is that the correct rear pad?
Old 12-05-2019, 06:57 PM   #12
d.j. moordigian
Bob and Russ..
That's what I use. I have 2 sizes, for the different size pads. I use 2" and 3",...the English
grinding flapper wheels work on them..
Dudley
Old 12-05-2019, 07:46 PM   #13
Don S
Hi. Guys , yes the picture of the backing pads is right, I have been using them for years, they will thread right onto the threaded mandrel that is threaded into my Dotco angle grinder . I cut down one of the backing pads to 3/4" for those tight spots. Just cut the disc to about 1""The discs are available in several grits,and are good quality.Make sure you use safety glasses. Cheers
Don S is offline   Reply With Quote
Old 12-06-2019, 01:27 AM   #14
Russ/40
Russ/40's Avatar
Originally Posted by d.j. moordigian View Post
Bob and Russ..
Dudley
Source please?
Old 12-06-2019, 01:41 AM   #15
CarlG
CarlG's Avatar
Originally Posted by Russ/40 View Post
Source please?
See post #4
Alaskan A's
Old 12-06-2019, 10:43 AM   #16
rogerkb1936
I have never seen that type
Old 12-06-2019, 12:00 PM   #17
Russ/40
Russ/40's Avatar
Originally Posted by CarlG View Post
See post #4
Old 12-06-2019, 12:00 PM   #18
d.j. moordigian
Source please?
Geez,....You live right down the street from S.D. There has to be an industrial
supply house the service's machine shops! You need to walk in with some of
pads so BOTH of you know what you have. I have both styles too attach the
different types of pads..
Dudley
Old 12-06-2019, 04:40 PM   #19
Don S
The older style of disc had a 3tab attach to the adapter. The discs were known to come loose and zoom away ,very dangerous. If you still have the old style I would not use them .
Old 12-08-2019, 01:21 AM   #20
flatheadrick
Try MSC Direct, page 1025 & 1026 of their on line catalog.
flatheadrick is offline   Reply With Quote
