05-27-2014, 05:54 PM | #1 |
Location: Northern Minnesota - The Cancun of the North!
1940/41 Pickup Cab Mounting
I am going to be mounting my 1941 Ford Pickup cab to my frame. I have new wood blocks & new bolt kit for mounting. I am wondering if I should use frame welting or rubber pads between the frame & the blocks? I don't remember what was there when the cab was removed if it was welting, rubber pads, or both?
05-27-2014, 07:25 PM | #2 |
Re: 1940/41 Pickup Cab Mounting
My original wood had a rubber pad between the wood and the frame. It was a belting type material about 1/8" thick. I found some at my local Orchard Supply Hardware store.
05-28-2014, 08:53 AM | #3 |
As TJ says there should be a rubber pad. You will find them sold in kit form in any of the restoration supplier's catalogue's.
05-28-2014, 08:57 AM | #4 |
Bob Drake sells rolls of the material.
05-28-2014, 08:38 PM | #5 |
3 pedals, 3 gears, no valve-covers.. Now THAT is a hot rod !! https://www.youtube.com/watch?v=ZmwwB34vxJE |
