05-19-2015, 09:15 PM | #1 |
Spark advance, GAV
New model A owner. Anyone willing to explain how to use the spark advance and GAV as I drive? Seems like the spark advance should be adjusted as driving conditions change; speed changes, up hill, down hill, under different load conditions,...
I just haven't figured it out. Right now I push the spark lever upmtomstart, pull it down once started but that's about it. Should I be doing more adjustments? Same question for GAV. How do I adjust and when?? Thanks |
05-19-2015, 09:35 PM | #2 |
Re: Spark advance, GAV
The link it to a copy of the owners manual that will explain it all.
http://www.motormayhem.net/wp-upload...ion-Manual.pdf Bob |
05-19-2015, 10:01 PM | #3 |
Go to MODELABASICS.COM & read their stuff about the spark lever & the GAV.
Bill W.
05-19-2015, 11:41 PM | #4 |
Please buy a reprint Owner Handbook.
Even the original first owners had to read up on starting & basic adjustments etc. |
05-20-2015, 12:35 AM | #5 |
I crank the engine with the spark lever all the way up. After cranking I run with the spark advance lever about 3/4 of the way down. I usually start the engine with the GAV 1/2 turn open and then close it to 1/4 turn open after the engine warms up. This seems to work for me.
05-20-2015, 01:38 AM | #6 |
