05-19-2015, 04:50 PM | #1 |
Valve lash
I am going to go thru my exhaust system, new gaskets, muffler, etc.i figure to check valve lash with all the room i have. Question, valve lash .013 intake, .015 exhaust , hot or cold ? Thanks, mike
05-19-2015, 05:48 PM | #2 |
Re: Valve lash
I do them cold unless the cam grinder has advised other wise
05-19-2015, 06:08 PM | #3 |
Re: Valve lash
I have never heard of a cam grinder suggesting to adjust the lash hot. Cold only.
05-19-2015, 06:37 PM | #4 |
Re: Valve lash
.013 intake and .015 exhaust ?
05-19-2015, 07:37 PM | #5 |
Re: Valve lash
That is correct for typical A engine. Some use .015 for both but most use or consider .013 / .015 to be standard. Unless you have a recommendation from the engine or cam rebuilder.
Steve Hanna, Polk City, IA |
05-20-2015, 07:31 AM | #6 |
Re: Valve lash
