06-05-2019, 04:07 PM | #1 |
56 crown vic glass top
how can I tell for sure if a car came with the glass top option?
06-05-2019, 04:34 PM | #2 |
Re: 56 crown vic glass top
If it was removed and filled in, there will be tell-tale signs of body work. Same if the whole top was cut off and replaced.
06-05-2019, 04:44 PM | #3 |
By the PATENT PLATE BODY CODE -
1955/56 F/L CROWN VIC - SOLID TOP (64A) 1955/56 F/L CROWN VIC - TRANSPARENT TOP (64B)
***** - MULTI-VEHICLE SYNTHETIC TRANSMISSION FLUID - Multi-vehicle transmission fluids are becoming more and more popular in the marketplace. Oil marketers design these fluids for a wide range of automatic transmission types. While they are not licensed by any specific auto manufacturer ... ??? ... enough said ... DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
06-06-2019, 05:14 AM | #4 |
thanks!!
06-06-2019, 07:32 PM | #5 |
The VIN plate is not a sure thing as reproductions are available that the manufacturer will change most things on request except the VIN.
06-06-2019, 08:36 PM | #6 |
Sal |
06-07-2019, 09:03 AM | #7 |
06-07-2019, 09:40 AM | #8 | |
The reputable folks who sell replacement data plates wont change the numbers of the serial number,body style,etc. They will change paint color codes and interior trim codes. There reasoning for allowing those changes are that if you were buying the car as new you should be able to get what color and interior combinations you wanted. Now I guess there could be some sorta shady charactors who would bogus a plate. BUYER BEWARE !!!!! Oldmics |
06-07-2019, 11:17 AM | #9 |
Sad on the bogus plates. I would be wary of a new looking plate and premium price. The plate should look 60+ years old. If it was a new plate seller should have the old one or state there wasn't one and adjust the price.
06-07-2019, 11:49 AM | #10 | |
I usually go one the a$$umption everyone is basically honest but human nature is what it is.
Case in point - http://oscarmotorcars.com/ford-listi...p-3-speed.html Quote:
You don't know if the seller was just not knowledgeable or trying to pull something. Big difference between a restoration and resto-mod.
06-07-2019, 01:08 PM | #11 | |
What tips you off other then it is a resto-mod. The price being high for that or what? |
06-07-2019, 03:55 PM | #12 | ||
There was a long thread here some time ago. EDIT- Quote:
