05-19-2015, 08:33 PM | #1 |
engine idles faster when gas is shut off
Whats is the significance of the carbs performance when I turn off the gas supply at the shut off valve and the engine idles faster just before the carb runs out of fuel ? Is the carb set too lean or too rich ?
05-19-2015, 08:45 PM | #2 |
Re: engine idles faster when gas is shut off
When you empty the carb do to the valve closed, the engine runs leaner just before it quits. You are not running too lean. Maybe or maybe not too rich. If you are running at best fuel to air ratio, what you are experiencing is normal. If you are running too lean you will not get the the slight rpm rise just before it quits. You need that slight rise if you mixture is correct.
Steve Hanna, Polk City, IA |
05-19-2015, 09:02 PM | #3 |
