01-08-2019, 07:14 PM | #21 |
Re: cleaning spark plugs
01-09-2019, 03:48 PM | #22 |
sorry book value
01-10-2019, 09:56 PM | #23 |
I’ll chime in, I’m considering about swapping out my champion spark plugs but not sure which brand to go with (Motorcraft, Autolite, NGK) to run a higher temp spark plug. My mechanic believes I have a weak spark and recommends rebuilding my distributor at some point to.
Are hotter plugs better? I can literally start and drive the car and those plugs are cool to the touch when I touch them. Whereas before I remember the last set of Autolite I had were hot. Any suggestions? Btw my mechanic said that he gaps his plugs to .035” instead of the manufacturer 0.025”. It will detonate the spark longer since todays gas has more additives. Sent from my iPhone using Tapatalk Last edited by dbtenner; 01-10-2019 at 10:28 PM. |
01-11-2019, 03:23 AM | #24 | |
Alan |
01-11-2019, 03:41 PM | #25 |
I gap plugs at .025" in a flathead. I have had failures on the HT side of the ignition. Having reasonable gaps keeps the loads down on the HT side. (HT = High Tension). I use Autolite 216s in my 59A motor.
01-11-2019, 03:49 PM | #26 |
01-11-2019, 04:35 PM | #27 |
H-10's in a 21 stud? right, got it.
Alan |
01-11-2019, 04:51 PM | #28 |
Thanks for the response. Maybe I should consider gapping to 0.025” instead of 0.035” again.
What brand and model of spark plugs y’all find the best for a 34’ head? Sent from my iPhone using Tapatalk |
01-11-2019, 09:56 PM | #29 |
H-10's in a 21 stud? right, got it.[/QUOTE]
Sorry Alan ,Glad somebody is paying attention,UD16s. My feeble mind is gaining on me. |
