02-21-2020, 04:16 PM | #21 |
Re: Serpentine System for Flatheads
That’s the one I was thinking of !
02-21-2020, 06:04 PM | #22 |
That Roberts design is a good find. It uses a little different orientation than the other setups.
02-21-2020, 06:11 PM | #23 |
It's starting to look like it can be figured out. The hardest part might end up being the sourcing of appropriate serpentine pulleys. I actually looks like the biggest hurdle might be just finding a crank and water pump pulleys that can be made to work.
02-22-2020, 10:34 AM | #24 |
I just made one for a friends project. I don't like v belts for street engines. It does help having the machines to make whatever parts you need. This is for a woman and she wanted AC, PS, and and alternator so this is how I configured it.
02-22-2020, 10:51 AM | #25 |
Very nice work . . . just not my style (given the vintage nature of flatheads). But - if somebody wants all those accessories, then this is a good way to go to drive them all and not have belt issues.
02-22-2020, 11:19 AM | #26 |
02-22-2020, 08:16 PM | #27 |
Serpentine belts squeak too. I have had much more squeaking on my two 97 T Birds and my diesel pusher. A serpentine system is no cure for squeaking belts.
02-22-2020, 09:20 PM | #28 |
>>>Serpentine belts squeak too. I have had much more squeaking on my two 97 T Birds and my diesel pusher. A serpentine system is no cure for squeaking belts.>>>
Much more? What kind of belts did they have before? And what are 97 T-Birds and a diesel pusher? Jack E/NJ |
02-24-2020, 07:29 PM | #29 |
Robert, that's some fantastic work. What are you doing for water pumps? It looks like the normal dual flathead pumps are not there. Must be something I'm unfamiliar with.
02-24-2020, 07:35 PM | #30 |
I used an ugh, 409 chevy water pump. I wanted the system pressurized with a modern sealed type water pump. Plus I couldn't put the accessories on the owner wanted with twin water pumps. Krylon 32 used to make a setup like this but I adapted it further to incorporate the AC and PS mounts.
02-24-2020, 08:57 PM | #31 |
Please whatever you do dont use a chain on a blower. Ya, I know there are examples from the past.
02-24-2020, 09:11 PM | #32 |
Really interesting Robert. I'll have to think a little bit to wrap my mind around that one.
02-24-2020, 09:19 PM | #33 |
It is impressive, but it looks like a ls3. I get it. Personally not my bag.
Super impressive... but I'm still dragging my happy ass around with my 95hp flathead. (Milled heads) https://www.hotrod.com/articles/flat...and-speed-car/ Buy a small block if you want air conditioning. . Last edited by Tinker; 02-24-2020 at 09:26 PM. |
02-24-2020, 09:22 PM | #34 | |
02-24-2020, 09:29 PM | #35 |
Robert, What did you use for the damper/crank pulley?
02-24-2020, 11:04 PM | #36 |
I had an old ATI super damper that the hole was worn out in, for a small block chevy. I bored the hole to fit the flathead and used a small block pulley.
02-25-2020, 06:47 AM | #37 |
Thanks Robert. That's a big help.
